It's supposed to be very clean inside and then it takes 250ml of gear oil. Now I know nothing of gear oils, auto, GL (?) 4, GL (?) 5 but there was a thread about that in the forum somewhere.hitlers revenge wrote:With the Help of Ron (all they way in PNG) I pulled one of my busses reduction boxes apart. Are they supposed to be full of grease? Why then have they got Oil fillers and drainers?????????
Removed the barn doors and serviced the hinges. In the process loosing one of the plates which the countershunk bolts bolt onto. The plate fell down the vertical channel. Had to cut a hole in the channel and make up a new plate. !@#$$%^%%$##@@
If you'd told me you were taking door hinges off, I would'a told you to keep one bolt in place at all times,
4 dayz...
