Some more stock - updated
Get your parts here
Hubcap
What model do you have?: 59 KG
Been thanked: 22 times
Post by Hubcap »
Just bought another joblot of new "old" stock for VW and Audi - have been sorting out:
411 big ends in 20 thou (0,5mm) - R200 a set -should fit all 1700/1800/914.
Piston ring sets - 1200/1300 (77mm) - std, 20, 30, 40 and 60 thou - the 20's and 40's I have lots, others very few
Piston ring sets - 1500 (83mm) - std, 20, and 40 thou - the 20's and 40's I have lots, others very few
Piston ring sets - 1600 (85.5mm)- 30 thou only
Piston ring sets - 1700 (90mm) - 40 thou - 1 set
Piston ring sets - 1800/1900 (93mm)- std - 3 sets
Piston ring sets - 2000 (94mm)- std - 3 sets
Piston ring sets also for Golf 1100, Golf/Jetta/Passat/Audi 80 1300 and 1500 - std only
Distributor caps - approximately 200 - sorry none of the early big ones - mostly EP145, but most others - R50 a cap
Points - most types - approximately 2000 - R40 a set
Rotors and condensors - large variety - R40 each
Mains(std, 10, 20 and 30 thou) and big ends for Golf/Jetta/Passat/ Audi 80 1300 to 1800 - R150 a set
Mains (10, 20 and 30 thou) and big ends (10, 20, 30 thou) for series 1 Audi 100, Super 90 - R250 a set
Just note that on the 1200/1300/1500/1600 rings there are several types - some both 2mm thick, some both compressions 2.5mm thick and some with 2 and 2.5 mm thick rings - depending on type of piston - so first check what pistons you have if you need to get. I do not have any of the 1.5mm rings. I am very negotiable on the 1200/1300/1500 20 and 40 thou rings if you take a few sets as I have a lot.
I will bring to Ferdi's swop meet.
Hubcap
082 802 5520
Hubcap
Re: Some more stock - updated
Post by Hubcap »
Updated
DDunc
Post by DDunc »
When is Ferdi's swap meet?
1969 Sunroof Beetle - Scratch Build in progress
1967 Beetle with 4 stud wheels and front discs - next in line for project
Hubcap
Post by Hubcap »
Hubcap,
Have you any old Audi 80/Golf engine spares?
Hubcap
Post by Hubcap »
Only rings and bearings as per list.
