911 speedster
marcel
What model do you have?: 1970
911 speedster
Post by marcel »
Hi All,
This is my first post on this forum. I am building a 911 motor in to an APAL speedster. I need some advice on a 36-1 dictator management system.
I am not sure about the placement of the missing tooth and pickup location. See picture of gear location on motor.
Re: 911 speedster
Sounds like an awesome project, would love to see more pics...
If you had Gotech, we could probably help as gotech is a forum member here.
Go to the diktator website and read through the manuals if they have them. It should be able to tell you how and why...
Has thanked: 45 times
Been thanked: 208 times
Re: 911 speedster
Post by Dawie »
Welcome Marcel.
Would imagine the missing tooth fits somewhere below the missing fan... :lol:
Just joking...
Will be nice to see some more pictures of your project.
BARON
Re: 911 speedster
Post by BARON »
Marchel,
What model and size engine have you got.
I got two manuals if you need help 72-78 which is typically the 2.4 lt to 2.7lt manesium block models and 84-89 which are the alluminium block 3.o lt to 3.6 lt models (last of the a/c s )
These manuals can be found on the net but Icant remember where
But first the pictures ,without that you will not get famous here.
cheers baron
Has thanked: 36 times
Been thanked: 50 times
Re: 911 speedster
Post by flatfourfan »
Pics!!!!!!!!!!!!!!
marcel
Re: 911 speedster
Post by marcel »
Some pictures of my project. I contacted three people listed on the dictator website and all three gave me a different answer of how to do the timing. I mounted the pickup for the gear, still not sure on what tooth to cut. I had to lengthen the car for the motor to fit. The motor is a 2.2l
Re: 911 speedster
Nice... Tell me more about those lights :)
Warren G
Re: 911 speedster
Post by Warren G »
Nice :hangloose: It looks good in white
Re: 911 speedster
wow.............that's unique...........kudos to you for doing something fresh........I'm seriously inpressed.
marcel
Re: 911 speedster
Post by marcel »
With a speedster you have two problems with the roof. Firstly the windscreen is to low and secondly the seats are too high. I made a role cage to support my roof and two fiberglass pieces that will fit inside the soft top for support. I made new lower seats, will see how they look when they come back from the trimmers. The rear lights are LED lights that I made. My tail, stop and indicators work from the same LEDs and I only have one wire plus the earth on each light. For the front I built LEDs in to the headlights for my indicators. I molded most of the wiring in to the body using copper wire that’s normally use to wire electric motors. I don’t have an ignition switch and when I press that red button on my dash I cut all power on the car, only the starter cable and wire to the alternator will still have power on them.
Bad Ass Bob
Re: 911 speedster
Post by Bad Ass Bob »
this is one KICK ASS thread, pity there arnt more in between pics, this sort of build takes a lot of balls, well done on your individualism,
BAB
BARON
Re: 911 speedster
Post by BARON »
I like the rear but I would use real 356 lights -- to old to like these small lights
cheers Baron
CooP
Re: 911 speedster
Post by CooP »
I'm old too but I really love the smooth look, nice cool white :hangloose:
Size does matter
Re: 911 speedster
marcel wrote:With a speedster you have two problems with the roof. Firstly the windscreen is to low and secondly the seats are too high.
If you have the right speedster seats in there, then they're just fine. They sit really low and even at 120kmh I don't feel any wind with the roof down. With the proper seats, you're almost sitting on the floor.
Hmmmm, angular roll bar isn't doing it for me though.........tail lights are also a bit too out there.
Still each to his own.
BARON
Re: 911 speedster
Post by BARON »
Different idea
Im sure this roof can be change to a removable hard top
cheers baron
