63 DC
- karmakoma
Re: 63 DC
Seems at one stage or another we all have that problem with our projects.
Lets call it a fundframe. In what fundframe will your bus be done
Could be next payday. next season, next year, next decade
- lowlight
- Been thanked: 14 times
Re: 63 DC
Start on the floor that I bought, take off some metal thats not needed. Need to get the big grinder out to do the rest.
- lowlight
Re: 63 DC
Took some more metal of the floor that I bought. I start to think it is easier to put new metal on than trying to use old metal. At this stage it is cutting and more cutiing to make things fit. Will get there slowly.
- lowlight
Re: 63 DC
What does sandblasting cost? Prices I got is a bit high for my budget.
Re: 63 DC
my heard goes out to you.....lowlight wrote:What does sandblasting cost? Prices I got is a bit high for my budget.
but seriously, with your air compressor, you shouldnt be asking how much it will cost for someone else to sandblast.....
Look into something like this
http://www.toolking.com/brand/mechanics ... aster-kit/
google "sand blaster kit"
- What model do you have?: 72 Early Bay Deluxe
Re: 63 DC
Wow this is a nice project.... At least urs is complete.. not like mine....
When I priced Sand blasting they quoted me about R1200 for the sandblasting and R700 to primer.. That was without seeing the van..
But this is a place in JHB..
Here details if you want to check with then..
http://blastandplant.co.za/services.htm
JRL BLAST <jrlblast@absamail.co.za>
Johan Lubbe
0823271375
Hmmm.. those sand blasting kits look interesting.. What else is need, beside compressor.. Where does the sand go into, etc...
Johan Lubbe
0823271375
Kuven Aramugam
E-Mail:
Contact #: 083 716 4455
Current Ride:2003 Golf 4 GTI
FRC - 76mm ATP DP and 63mm Wildcat Zorst - Forge TIP - Forge DV.
Project - '72 Early Bay Deluxe
E-Mail:
Re: 63 DC
I think you dunk the flexible hose into the sand and use the gun like a spray gun
- lowlight
Re: 63 DC
Kuven, was thinking along those lines, here they are between 3 and 5, closer to the 5 mark. Need a heap of grit and then a place were you can make a mess.
Tony, thought about it last nigt and will give it a shot, just the time factor, if get dirty then it must be worth while not just one hour at a time.
Re: 63 DC
hmm... ok kewl.. I though it would go into some sort of tank or bottle.. But how this one, with bottle attached.. Wonder how they are..Tony Z wrote:I think you dunk the flexible hose into the sand and use the gun like a spray gun
http://www.oneshop.co.za/p~gilmour-hand ... l#descMore
Kuven Aramugam
E-Mail:
E-Mail:
Re: 63 DC
Ouch 5K to sand blast does sound very expensive..lowlight wrote:Kuven, was thinking along those lines, here they are between 3 and 5, closer to the 5 mark. Need a heap of grit and then a place were you can make a mess.
Kuven Aramugam
E-Mail:
E-Mail:
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Re: 63 DC
Hey Lowlight ! Just reading your thread for the first time, great stuff, good luck with the rest of the restoration
