sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
Replaced 1/4 light window this evening as the plastic knob on my one was broken. I had to switch the frames and glass as the one with the unbroken knob had some sort of light tint in the glass, it came from a 1979 executive bus and it is marked anti-sun on the glass. I see my clear glass does not have this stamp. All the windows that I have from this 1979 executive bus have a tint, and it's not a stick on film. Anybody seen or heard of this before?
Here is the broken knob off my bus.
After good 1/4 light window installed.
CooP
Post by CooP »
Finally stopped gardening for long enough to get a bit of bus work done. I've tidied up the welded up sliding door on the left:
...and I've done some more sandpapering and flatting on the front. I've just blathered some red oxide over the whole lot as the rain is killing me. Still got a lot of high spots and dips to sort out but at least it's starting to resemble a bay-window front again.
Size does matter
Hloni
Has thanked: 14 times
Post by Hloni »
Replaced my oil-filled coil late last night, cranked it and it ignited at the 2nd swing! Somehow my bug is chowing the coils, not sure why :shock:
This morning drove down to Eston and back - lekker cool drive down, but coming back it seems like the engine is running a tad hot once again, although I have a tennis ball :cry:
3011
Ruann007
What model do you have?: 1970's odd buggy
Facebook: Ruann Kotze
Post by Ruann007 »
Did a bit of work over the w/end :D
- Replaced brake master cylinder
- Serviced Carb
- Replaced Points and condenser
- Replaced front wheel bearings.
- Oil change
- new spark plugs
- new dizzy cap
- new plug leads
Now anyone know of a place I can get some bits Sandblasted around centurion... Tried Ridge Powder Coating but the guy wanted R120 per wheel .... Was a bit steep.
A car for the people, an affordable Volkswagen, would bring great joy to the masses and the problems of building such a car must be faced with courage.
Adolf Hitler
BUSBFK
Post by BUSBFK »
After unsuccessfully trying to source a exhaust for my bus from Volkspares 3 times(every time I was told 2-3 weeks and it is here) I decided to talk to my dad end he donated an empi(He thinks it is one but not sure) performance exhaust from his spares. I fitted that the weekend will take pics tonight. Must say the bus is now running like a bomb and sounding sweet. And did the following as well.
-Changed oil
-Adjusted Brakes
-Adjusted Handbrake
-Adjusted Clutch
-Adjusted Tappets
-Fitted new points and condenser
-New spark plugs
-Adjusted Timing
-Greased the nipples
Now Flossie is in tip top condition.
CooP
Post by CooP »
Hey BUSBFK, time for a visit and you can show me around the suburbs again.
Size does matter
BUSBFK
Post by BUSBFK »
CooP wrote:Hey BUSBFK, time for a visit and you can show me around the suburbs again.
Hi Coop
Actually drove past your house last night (Test drive) after I wrap a section of my exhaust as it is getting to hot in the engine bay. What a :bn: job to wrap with that fiber glass stuff. My hand are still full of the :bn: but it is working like a bomb. Drove to work this morning and engine bay is much cooler. You must hear my bus now it sound great will pop in this weekend some time.
CooP
Post by CooP »
Look forward to seeing Flossie again (and you too, ahem). I am only 5 mins away if you ever need help with things...
Size does matter
Hloni
Post by Hloni »
BUSBFK wrote:Actually drove past your house last night (Test drive) after I wrap a section of my exhaust as it is getting to hot in the engine bay. What a :bn: job to wrap with that fiber glass stuff. My hand are still full of the :bn: but it is working like a bomb. Drove to work this morning and engine bay is much cooler. You must hear my bus now it sound great will pop in this weekend some time.
Where be the snip snaps of this majestic work? Teach us...teach us please :drunks:
3011
Post by 1972 »
I built a 30 inch, narrowed beam :hangloose:
Post by 1972 »
Just for the shock-less haters!
Klaus
Post by Klaus »
Replaced the fuel line on Ruby the bay - relocating the filter out of the engine bay - yummy job working underneath with fuel. :D
Ruann007 wrote:Did a bit of work over the w/end :D
- Serviced Carb
- Oil change
- new spark plugs
- new dizzy cap
- new plug leads
Give Neil a call - 082 417 4558, also in Centurion, his prices are very keen :)
Ruann007
Post by Ruann007 »
Blitzkrieg wrote: Give Neil a call - 082 417 4558, also in Centurion, his prices are very keen :)
Hi Thx Blitzkrieg
I gave Neil a call, prices are very good.
:hangloose:
Adolf Hitler
Farhaad
Post by Farhaad »
last night i handed over the registration docs to the new owner of 'ol 66 :( :( :( :( :( (a sad day in hell)
