Recon Type 3 rear engine mountings - On exchange
Get your parts here
Variant
What model do you have?: '69 316 & 362
Post by Variant »
Greetings everyone
Since a few more type 3's have come out of the woodwork: I am offering reconditioned rear engine mountings for all Type 3's with manual transmissions on exchange. These mountings are becoming almost impossible to find in useable condition. Have a look at the pics below - the original rubber insert gets replaced with a polyurethane casting of similar stiffness and as result of the casting process one ends up with a slightly larger contact area so the recon mounting should provide even better stability and last much longer than the original. I've had one on the Notch for about two years and it works very well - no more bucking/shunting if you let the clutch out quickly. The price is R450 each to anyone on the forum - excluding postage. Depending on demand I should be able to dispatch within a week of receiving your old mounting. Please PM if interested.
If there is demand I will look into having the spacers between the body & mounting made up as well.
Adriaan
'69 1600L Squareback Automatic
'69 1600A Notchback
Re: Recon Type 3 rear engine mountings - On exchange
Variant wrote:Greetings everyone
I am now in a position to offer reconditioned rear engine mountings for all MT Type 3's on exchange. These mountongs are becoming almost impossible to find in useable condition and by now probably every T3 out there needs one. Have a look at the pic below - the original rubber insert gets replaced with a polyurethane casting of similar stiffness and as result of the casting process one ends up with a slightly larger contact area so the recon mounting should provide even better stability and last much longer than the original. I have been testing one of these on my Notch for some time now and it works very well. Due to material cost the price works out to R500 each and depending on demand I should be able to dispatch within 1 day of receiving your old mounting. Please PM if interested.
If there is demand I will look into having the spacers between the body & mounting mady up as well.
Since I am new to Type 3s, could you please explain what "MT" means? :zhelp:
Variant
Post by Variant »
MT = Manual Transmission. Automatics had a completely different engine & transmission mounting setup.
Adriaan
'69 1600A Notchback
This is an excellent initiative - NOS ones were around R1500-00 the last time I checked.
Variant
Post by Variant »
Bump
Adriaan
'69 1600A Notchback
s-thang
Been thanked: 4 times
Post by s-thang »
Hi!
Any luck on type 4 mounts?
thanks
S
Variant
Post by Variant »
s-thang wrote:Hi!
thanks
S
AFAIK type 2 & 4 used similar mounts from 1970 onwards. I don't have any, sorry.
Adriaan
'69 1600A Notchback
Has thanked: 19 times
I see 3 mounts in the picture are they fast back / Notch / Squareback or how do you determine which one should be used ?
Variant
Post by Variant »
Bugger wrote:I see 3 mounts in the picture are they fast back / Notch / Squareback or how do you determine which one should be used ?
All type 3 models with swing axle rear suspension use the same mounting. Three mounting are shown together because I had them cast together... :)
Adriaan
'69 1600A Notchback
Variant
Post by Variant »
Bump...
Adriaan
'69 1600A Notchback
Variant
Post by Variant »
Another bump...
Adriaan
'69 1600A Notchback
