The time has come to upgrade my '69 Notch's brakes to someting that will actually stop the car in a reasonable distance and mostly straight line. Getting the brakes to work properly has been an ongoing battle for as long as I've owned the car and all the issues boil down to the fact that by now just about every T3 brake drum out there is either out of round or too thin from being machined too many times. (Or both...
So, being a certifiable old-school, stock, numbers correct type guy, I have embarked on upgrading the brakes and related hardware to the same spec as my '69 Squareback Auto. In other words, 4x130 disc/drum and tandem master cylinder. On the Square this system has proven to be very reliable and low maintenance. Best of all - replacement parts are readily available at reasonable cost.
The project has progressed from the planning on paper stage to sourcing and refurbishing of components and the actual conversion will start once all the bits & pieces are ready. I've made a list of all the parts required and will be keeping track of the expenses related to each item - will post this here as soon as all the parts are ready. Pictures of the parts & process will also follow.
