Brake wheel cylinders bus
- Been thanked: 98 times
I have new brake wheel cylinders for T2 bus 1964 to 1971 front & rear. These are good quality Varga items.
R250 each if you have leaking wheel cylinders, or looking at rebuilding the items you currently have, then these are what you need.
I can also get master cylinders, or if you need any of these items for beetles or earlier buses I can get them, if you insist on German items they are also available.
Rui 082 830 6493
Rui 082 830 6493
- Oil Leak
- What model do you have?: '63 bus and '65 911
Re: Brake wheel cylinders bus
Hi, have you got pictures of these or the part number, i have bought previously for my '63 bus (front) but they are different. mine has an arc between the two holes where it bolts on (if that makes any sense) those that don;t fit have a straight piece of steel.
cheers,
Kevin
cheers,
Kevin
63 was a change over year, these will not work on a 63 for 64 & up, sorry.
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Rui, can you get the pre-63 brake cylinders? I will need two sets during the course of this year. How does the price compare with the 64-71 parts?
The 55-63 wheel cylinders I can get are original German been looking at other suppliers but no one has them.
Price.... are you sitting down......
R950 each for the front
- fig
- Bus Driver
OUCH!!!
For that price I'd rather rebuild what I have. Please let me know if you find them cheaper at acceptable quality.
Still have stock, anyone ?
Got more in ......
I can get for earlier busses as well front 55-63 R320 each, you will need 2 for each front wheel & 1 for each rear wheel.
The rear are the same from 55-71 R250
Let me know, I will need to order them.
- Dam
- Flywheel
- What model do you have?: A few
- Been thanked: 7 times
OK, so rears are the same for all those years. Then I don't need right now. I have a leaking one on the '58, but a new spare one I bought for the '66 but never used. Guess what I am doing tomorrow?
