Fixed 2 hubcap clips so as to replace my Hubcaps.
Eugene Pfeil
What model do you have?: 68 beetle
Post by Eugene Pfeil »
Installed a new engine lid rubber
hitlers revenge wrote:Fixed 2 hubcap clips so as to replace my Hubcaps.
What rivets did you use to fix the clips (on the bus or Ghia Dave) ?
@Jolas
4.8 x 12mm peeled rivets. Riveting from inside the rim. IOW, the peeled end is wrapped around the clip behind the hubcap. It doesn't look at all kosher but at least the hupcap can now stay in position.
@Jolas, if you want rivets , I have 23 of them left. :lol: You are welcome to some. :lol:
hitlers revenge wrote:@Jolas, if you want rivets , I have 23 of them left. :lol: You are welcome to some. :lol:
Thanks Dave. I used some "new" clips recently, Oom Hennie helped me rivet them on, but one has already broken, they just don't seem to be as durable as the originals, it's not like I take my hubcaps on and off every day ........ ?
Are you working on the panel van ?
Panel Van?? The red one. No. The clips came off my ghia rim.
I might sell the panel for spares.
Has thanked: 19 times
Yesterday I sorted out both of my Syncro`s diff lock vacuum pumps coz they were not functional as we are going with a few Syncro`s to Hennops 4 x 4 track on Sunday
and I really want to take my Syncro Off road again with the propper "Tools" :lol:
Changed Tyres and fitted the spare set of 14" Rims with better Off road tyres and just basically prepped the bus for the run
Has thanked: 425 times
Been thanked: 543 times
hitlers revenge wrote: .....I might sell the panel for spares.
Which panel, lets have photos.........
Donovan D
Has thanked: 150 times
Been thanked: 73 times
Post by Donovan D »
Dropped the fasty with two outer splines in the front, The car is now level, not nose up anymore and looking pretty sweet
Stütz
Been thanked: 19 times
Post by Stütz »
X2
3104
Splitz wrote:Dropped the fasty with two outer splines in the front, The car is now level, not nose up anymore and looking pretty sweet
How is the ride and do you have any suspension travel?
Mine is sitting 2 down in front, still has quite a bit of suspension movement and only hits the bumpstops if you hit a really bad dip or bump in the road, other than that it sails fine with a firm ride.... :hangloose:
See vehicles - Brazillia Panel for pictures
Donovan D
Post by Donovan D »
Blitzkrieg wrote: How is the ride and do you have any suspension travel?
The ride quality is 100% better its a lot stiffer in the front and not bouncy like it was.
Travel seems good, took it for a bit of a drive today and did not hit the bumpstops.
And its really easy to do
Excellent! :hangloose:
I have found those parts that you are looking for, the armrest is pretty decent with just a little bit of attention required and the ashtray is a perfect, just needs some paint 8)
