A bit of work to be done. The workshop has been cleared out, ready for the new work load, although this baby now runs like a dream.
The first thing we sorted was the missing gasket on the inlet manifold, which was causing major backfire any a probable fire if it wasn't sorted asap. Once this was sorted we took it for a test drive only to hear worn wheel bearings.
On inspection this turned out to be a loose front wheel hub nut.
Now to sort out some wiring issues and then some body work. Then she'll be as good as new.
