148 old numberplates wanted
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Hi all
I am currently building a sort of man cave for the storage of my running cars as I have totally run out off space
it will be 100m2 with some space for storage and recreation.
I am looking for forum members to send me old numberplates to mount on the exposed roof beams.
I need at least a hundred and forty eight plates (not square ones) to mount
Ideally I would like the forum member that donates nickname written on the plate as well as his real name. (not on the back as that will be stuck to the beam.) so that each plate tells a story Your town would be nice as well
I am looking for any plates current ones are ok but old ones better
If you can post to PO Box 220 Orkney 2620 I will be very glad
Herbie
What model do you have?: 1978 Beetle SP 1600
Been thanked: 35 times
Re: 148 old numberplates wanted
Post by Herbie »
You guys can send very thick lead number plates as well, his foundation will handle it...you should see his foundation :shock: man-o-man thats a proper foundation....
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
MINCE
Post by MINCE »
Wow, I don't have any licence plates! Good luck! Nice body in the background there
Drusky
Has thanked: 77 times
Been thanked: 15 times
Post by Drusky »
When we built our factory I put up a separate structure 24m long by 8m wide using galved IBR (white) and galved channel iron and 75mm galved square poles. It looks quite neat and cost about R50K in materials (structure only not floor/ foundations). Are you building in brick? Are you doing it yourself? What will your roof be made of? My structure was about 4m high and flat roofed. I built it two years ago. If I ever build a man cave I would like to do it the same way. I wonder what the municipal by laws would say about a neat shed in my yard. Do they even care anymore?
IMPI
Post by IMPI »
The plan for my building will be to build 4 portal frames from 160 x 82 I beams standing free on 8 legs from the same material
the roof will be corrugated iron and will have a 20 degree pitch to match my house
Walls will be built from maxibricks to a height of approximately 3.2 meters
the roof will overhang the walls by about 500mm
the underside of the roof will be covered by a white bubble wrap type material as seen in Game stores so that only the roof beams are visible and they will be decorated with the numberplates.
I will add further photos in the project build section
IMPI
Post by IMPI »
DR WATSON
Has thanked: 7 times
Been thanked: 4 times
Post by DR WATSON »
I'll send a couple of my old plates to you next week :hangloose:
IMPI
Post by IMPI »
