Lowered two splines in the front to level the car
Its a good solid body. Dont have any problems at the moment except for a dodgy fuel gauge.
Due to rubber and other leaks, the water gets into the old, cotton/Hessian sound proofing, and when the car stands in the sun the condensate goes up the pilers, and turns back into water on the roof liner.Hloni wrote: What causes the discolouration of the lining? Yes, I know 'water' is the easiest response, however, how does one get water there as this example seems rather common on our classics?
Hi Splitz, know where you can get a nice NEW dash.......Splitz wrote: ......
Jolas the dash is cracked across the centre grill but its not that bad.
I heard that "shower cleaner" will take off water marks, but PLEASE test it 1st on a unseen place, (under light fitting maybe)Splitz wrote:Is there a way to get it clean ? I tried sugar soap but it doesnt work
