Fomula Vee Rebuild
JamesD
Been thanked: 20 times
Fomula Vee Rebuild
Post by JamesD »
Sup guys, as you know, we picked up the Vee from Triton. Here are the pics from when he found it...
Then Triton did some work on it, and the work he did was fantastic! the dash, steering column and front clading were done exceptionally well.
Then we stripped everything yesterday and began the rebuild. Full paint off and respray of frame, front suspension the works
the frame was riddled with holes, my word, but those got welded up. Got resprayed today as well, but no pics yet. car should start going back together tomorrow. alot of work to still do. we only fixing up the front as the rear still needs some modifying.
And on the bright side, the Birkin just just fits on the trailer, well, until i install the wide track suspension in a month or so...
From fastest to slowest:
'75 SP 1600 with a few mods
Klaus
Fomula Vee Rebuild
Post by Klaus »
Can't see the pics for some reason. What motor are you going to put in her ?
Has thanked: 235 times
Re: Fomula Vee Rebuild
:hangloose: Looks good!
I'm very fascinated by the 'reverse linkage' of the gearbox, can you please post some closeup pics?
JamesD
Post by JamesD »
not sure why you don't see the pictures, I uploaded them to ACVWSA. Probably a 1600 twin port will go in with a 36 weber to learn with at track days and then we will modify the engine to match regulations as needed.
Will snap some pictures later or at some stage Pine, we will probably remake the linkage since the current one has been modified to fit a water pumper at some stage and is rather floppy and hard to operate. AND the gearbox is an SFAS, which means Pierre might get a call if we need to go faster down the straights before running out of revs...
JamesD
Post by JamesD »
Going back together...
JamesD
Post by JamesD »
So it all started going back together...
And for Pine
Thanks, James! :hangloose: Is the 'shift pattern' the same as a standard Beetle, with the gearbox the other way around?
Has thanked: 19 times
JamesD69 wrote: AND the gearbox is an SFAS, which means Pierre might get a call if we need to go faster down the straights before running out of revs...
I am actually buzy with 2 Vee ttransmissions but they are not the SFAS type. They are the 4.125 R&P and a 0.93 4th gear which is a shorter than STD 4th according to the regulations for vee but are you guys going to enter Vee Races or just play at Track days ?
But Bring it Anf Yes I can Do It :lol:
Klaus
Fomula Vee Rebuild
Post by Klaus »
JamesD69 wrote: Probably a 1600 twin port will go in with a 36 weber to learn with at track days and then we will modify the engine to match regulations as needed.
Would be cool to see it in action on a Sunday track day. Let us know and we can come and watch and set up a braai.
JamesD
Post by JamesD »
Standard shift pattern Pine, I'll show you how it works some time. basically you pivot around the bottom of the gearlever not the middle like on a bug. this gives you the correct throw direction.
Pierre, are those boxes for aircooled cars or the later water pumpers? we staying aircooled and looking at racing in the vee races and historic single seaters.
Sounds cool, can do a braai at a track day Klaus, just gotta get the car ready to go racing first. think they want to stick an engine in and run it next weekend...
Just a few things to note so far, the suspension at the front isn't lowered, the shocks are just so short they are pulling the whole car down. think it needs a selecta drop to lower the front "naturally", should also improve the handling a lot.
The steering wheel is a bit too far forward, it needs a spacer to bring it backwards so you can sit comfortably in the car.
The seat, not so comfortable or the safest, might take the seat out of the Birkin and chop it shorter and stick it in the Vee.
Has thanked: 425 times
Been thanked: 543 times
JamesD69 wrote:Standard shift pattern Pine, I'll show you how it works some time. basically you pivot around the bottom of the gearlever not the middle like on a bug. this gives you the correct throw direction.
Hi,
If you guys need racing info, try to contact the Venturi brothers, as they are or where very into V racing.
They had the Venturi Motors in Wynburg.
Sure you can google then,
Nice guys and very helpful.
It is for the later water pumpers I am doing the boxes for atm
Hloni
Has thanked: 14 times
Post by Hloni »
And what shocks are those - what car they from?
3011
JamesD
Post by JamesD »
Nope, Even if i knew i wouldn't tell you, cause some one will get it into their thick heads that that is a cheap and easy way to lower their car... So dont even ask for a part number!
4agedub
Been thanked: 13 times
Post by 4agedub »
Looking really good there. I've always wondered how one of the vees would run with a close ratio gearbox and 200hp t1 engine :) I'm sure it will be fun to drive
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
