58 beetle project with nitrous
- Has thanked: 36 times
- Been thanked: 50 times
Re: 58 beetle project now with nitrous
Yup..........just looked again and nose in the weeds, ass in the air is more my taste........
- marius 58 bug
- What model do you have?: 1958 beetle
- Has thanked: 3 times
- Been thanked: 5 times
- marius 58 bug
Has any one got any advice on a new ignition system. I have the golf system but I'm not to happy with it
If it's to low you to old
- JamesD
- Been thanked: 20 times
Well since you do seem willing to spend some cash, why not look at the pertronix system. I've got it and i'm happy with it.
From fastest to slowest:
'75 SP 1600 with a few mods
- dubster
- Been thanked: 3 times
se ons eers hoe dit voel as j gas klap op n beetle? if i may ask again did you use this kit from turbodirect
or where did you source the kit?and does the kit come with everything needed or is there a few more things to get with it?o and how many horses are you spraying?
1974 1300tp type 1
kart kraft 1717cc buggy
- dubster
maybe look at this if you want to pull out some bucks.
http://cbperformance.com/catalog.asp?ProductID=1726
otherwise look at the rest of their line up.
http://cbperformance.com/category.asp?CategoryID=12
to order from them just look up rui a.k.a calooker up on the site
found this aswell looks awesome
http://www.123ignition.nl/id/50.html
but a bit pricey
http://global.ebay.com/123Ignition-univ ... 48512/item
but a bit pricey
1974 1300tp type 1
- marius 58 bug
Thanks guys I wil look into it . I also like this system but I think you will need a ecu
- dubster
ja that is actaully the way to go then just get a ecu to drive the ignition and then you have the ecu to go FI later?ps hoe many horses are you spraying and how does it feel and does the motor like it?
1974 1300tp type 1
- marius 58 bug
Gone spray 75 HP . Still got lots to sort out, will run it in about 2 or 3 weeks but will keep you up to date
- dubster
1974 1300tp type 1
- marius 58 bug
Motor should be ok all forged parts. Running a holey fuel pump and regulator.
- dubster
nice
waiting on next updates ,
keep well....
keep well....
1974 1300tp type 1
- marius 58 bug
Re: 58 beetle project with nitrous
If you are going to go that route... why not use Gotech? Neat install and local support.marius 58 bug wrote:Thanks guys I wil look into it . I also like this system but I think you will need a ecu
Here is mine
- marius 58 bug
