Luckily I conveniently arrived in the parking lot at work when it happened. My initial thought was running out of petrol again but on inspection later on in the day the fuel filter was completely clogged. Being rather annoyed got Tonia to bring me another, swapped it, got a bit of fuel through and then the new accelerator cable broke, right at the front.
So ended the day with Tonia towing me home and checking at home that I again can get now fuel through.
I suspect the tank is rusting inside and has now clogged the fuel lines.
Does anybody know if a tank should be treated with some sort of chemical or paint after cleaning? It was soaked for some time in some type of a acid mix to clean the rust out and was spotlessly clean when I installed it, but something is obviously going wrong.
Any ideas?
