mods please move if this is in the wrong section.
what work is needed to convert from a generator to altenator on a beetle? is it just a matter of fitting the alty and stand, or must some wires be fiddled with too?
Ryan
Genny ---> Alty
- MarshallGTi
- Camshaft
- Has thanked: 7 times
- Been thanked: 11 times
Genny ---> Alty
Ryan Marshall
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
Re: Genny ---> Alty
some wires aswell ,if you get a alternator with an internal regulator
also check
http://www.nls.net/mp/volks/schem/gen_alt.htm
also check
- MarshallGTi
- Camshaft
Re: Genny ---> Alty
useful link, thank u buggy
Ryan Marshall
- Klaus
- Has thanked: 13 times
Genny ---> Alty
Alty, stand and Alty pin for the fuel pump relocation. Some patience
- MarshallGTi
- Camshaft
Re: Genny ---> Alty
Tell me more of this fuel pump move?
Ryan Marshall
- Klaus
Genny ---> Alty
The two different stand types make the fuel pump sit higher or lower thus there are different pins for the generator stands and the alternator stands.
So if you change stands then you need to change the pin to the opposite one you currently use.
