Stef se Squareback
Stephanus
What model do you have?: 1967 Variant
Has thanked: 3 times
Stef se Squareback
Post by Stephanus »
09 June 2012
This is going to be fun. I've never tried it and i know very little about cars and or restoration.
30 June 2012
Bumper bolts broke off in the chassis and and so far i've drilled out two of them.
Also removed and cleaned the Carburetors Solex 32 PDSIT 2 and 3.
Stephanus
Re: Stef se Squareback
Post by Stephanus »
Carb number three had some bolts missing that attaches the heater element to the upper body assembly. Also knowing nothing about carbs i noticed on the underside of the carb that there is a tube with a little float. This tube is part of the upper body assembly and is next to the heater element. The bottom of that tube is open. Is it supposed to be? The one on Carb 2 is closed.
Hi - thanks for posting pics of your project, looks like a nice solid car ? Is that the original colour ? What are your plans ?
For some reason I can't open you photos to zoom in ...........
Nice to see some squarebacks popping out all of a sudden :D
Good luck with your project
Stephanus
Post by Stephanus »
Yes that is the original colour but it has been resprayed in the past (as is evident from the paint on the Chrome, the wiring, the wheels etc.)
Planning to get the motor running and roadworthy for now and longer term it is for my son to use while he is at college.
Stephanus
Post by Stephanus »
Ok, so the hole in the carb must be covered. Well, here is my 2cents worth, from 1994, 18mm diamtr.
Uploaded with ImageShack.us
Stephanus
Post by Stephanus »
Drilled out the left fixtures for the bumper brackets today. And i eventually stripped all the paint off the hubcaps. These hubcaps are cool.
Stephanus
Post by Stephanus »
ok, i need help to do this untill i need to call in the Pro's, i am \trying to get the engine going. i've redone (cleaned the Carbs) i suppose i should set them, i.e. one and 1/2 turns back etc, but what comes after that fails?
Has thanked: 19 times
HI Stef Lekker om jou te ontmoet het gister :hangloose:
MrT
Has thanked: 22 times
Been thanked: 9 times
Post by MrT »
Stephanus wrote:ok, i need help to do this untill i need to call in the Pro's, i am \trying to get the engine going. i've redone (cleaned the Carbs) i suppose i should set them, i.e. one and 1/2 turns back etc, but what comes after that fails?
Have you replaced points, plugs, coil and condenser? Is the timing set correctly? That is were I will start.
Good luck!
Stephanus
Post by Stephanus »
Jeeesz, ... all that. If the wiring isn't in place will any of that work? Yes, i suppose they willl. Plugs have been replaced, suppose i could set the points, but checking the coil and condenser, i'll have to check the manual, i'd like to have the engine running but i suppose i'll have to start at top dead centre. (or something like that. i haven't touched an engine in years! i have also not named my (son's) '69'ish Variant yet). Met some ACVWSA guys at Swartkopz this weekend. Green Buggy, 6 Dubs and a Bus (Ok one orange dub looked rat, didn't see the underside though. One Dub that was published just after the splittie ('58) i think, one cool green flowerstickered campervan, some white rubberised (or some snakeskin look, plastisized) awesome Dub and some more. Two cool dub roofracks. Great wheels & tyres, some greenwalls, some redwalls. I noticed an enormous (absentee) representation of of Type 3's, Kharmann Ghia's, Variants, Fastbacks or Notchbacks.Or things or Off Road, Track cars, etc. C'mon guys, those cars way are cooler than a MG, Merc or Posche anyday. .........(OK, the old ones where cool,... and the very new big ones...except for the MG's there was one red very cool old red (porsche, i think) car and an old Merc that looked like a 300c Gullwing, but wih doors.) bought a model of a rusted fastback (will publish photo) for R14 less than the offerred price (R119 for a nice clean maroon (not rusty looking)1:18 model at a Toystore). The guy gave me discount for queing to buy him a boerie since he couldn't leave his store. I also drilled out the right hand side broken off bumper bolts and cutting new threads. the bumper is almost done. i need one self tapping chrome bolt on the underside of the bumper, then that much of the car (from front to back) is fixed.(not rust free or painted yet.) Also,..... The hubcaps are free of paint!
Stephanus
Post by Stephanus »
Yesterday I started the day full of hope and planning to remove the driver's seat. As per recommendation I Q20'd a small can on it and kicked it from behind while my son sat on the seat and held up the lever between the chair base and the door. I kicked it again. I told my son to get out and i pulled it. It moved about a centimeter. This was when I noticed that there is a failsafe stop (for lack of a better word) on the "tube" (tube explained later). It is like an "L" shaped piece of flat steel (turned 90deg clockwise), when bent upwards, it faces towards the back of the car, with the L bit facing towards the floor. So when you try to push the seat forward, the channel slams into it, thereby preventing the chair sliding forward. Fortunately my timeous detection of this built-in "Accidentally Slide Forward" failsafe system prevented me from having to replace that as well. You just push it into a hole and the chair slides forward, past it, but not yet all the way out. So, son back on seat, kick it, son off seat, pull it etc etc. Eventually it moved all the way back! Now, if I kicked it from behind it had to go all the way forward, NOT.
This mechanism of the "chair sliding",.... I will try to explain using my limited terminolgy since I am not yet fluent in VW speak.
"Now you see, the seat is attached to a base which slides forward and backward. This base slides because... attached to the base is a channel wich, kind of, folds over a tube. The tube is attached to the body of the car. Actually there are two tubes, one on the left and one on the right, and both of them have channels (attached to the chair base) sliding on/over them".
"Inside the tube, there seems to be rod with a nut on the end. Only, the nut looks like it has a bowler hat on. These nuts are on either side of the bolt which protrudes on the front and the back of the tube. These nuts both broke off which brings me to my next point."
"To see what is inside the tube is not possible unless your head is flat enough to fit snug against the elevated centre (console) of the pan or floorboard of the car."
"The only reason one would like to be able to look inside this tube would be to see if there might be something (like the rest of what was attached to the nuts) that prevents the chair from sliding out, which brings me to my next point."
"There is also a piece of plastic between the channel and the tube. I'm not sure which one it should be attached to (channel or tube) but when it breaks it inhibits movement/sliding of the chair. When it disintegrates, it is even more dificult to decide where it should / should have fit or where it's parts may be lost within this system."
This is my simple sketch from memory of how the system works. Oh yes, I also noticed some springs, towards the back of the seat, sliding in the tube.
Since the chair was now stuck in the "As far back as possible" position, I decided to work on the fusebox. Aahhh, Nostalgia. As I'm sure many members of this forum are familiar with ceramic fuses with little strips of lead over them, I'm sure I'll be excused if I replace these with a more modern version. I also tracked down a company which manufactures Auto electrical wire but they cannot supply directly to the public. Being a self employed trader at one time didn't help either. She did however refer me to an outlet and the lady who answered the phone took down the colours and thicknesses of the wire over the phone untill I asked if it wouldn't be simpler for me to just e-mail th wiring diagram and she could check availabilty for me. She said she'll call back. I'll call tomorrow.
And on a lighter side, I paid VdBrink's a visit last week Monday and found this.... it holds the right rear reflector, dunno it' scientific name.
