Fiat 126p - Aircooled 650cc 2 cylinder
- Site Admin
- Been thanked: 54 times
Re: Fiat 126p - Aircooled 650cc 2 cylinder
Got a video of the clutch action... nice to have a cover that you can remove to reveal the secrets...
- Site Admin
Working on a "rough" test manifold to try out the carb. There might be an issue clearing the ignition leads....
...& yes... I know the flanges are too thin.. I'm kind of limited to using a grinder, hacksaw, drill stand and grinding stones to make stuff but once this works I might make it more sturdy. ;D
I would need to support the carb anyway.
- Site Admin
YAY! I didn't adjust anything yet... but it works niiccee.....
Remember this carb doesn't have any jets. Adjustments are a air bypass, throttle butterfly position and WOT enrichment screw...
What do you guys think?
Next thing is to make it permanent.
No flat-spots like with the 28IMB Weber.....
- Retrobug
- Has thanked: 15 times
- Been thanked: 32 times
Looks cool!
What are the plans for the air filter?
Hope it's something period looking!
- Ron&Gill
- Been thanked: 21 times
Ag, nee, foei, dit lyk alles dan so mooi, en dan? Dan jy weld nes ek!
- Has thanked: 425 times
- Been thanked: 543 times
Eben, have you had the fiat on a fuel analyser yet, is the fuel mixture correct through the full rev range??
That carb is more simpler then the Webers, but look and sound great,.
I think we should all go that way. it they correct. what is your fuel economy compared to the original carb.?
- Site Admin
Hi, no no tuning yet. I will start the rough tuning this weekend and maybe use a colortune later. This Carb has an interesting tuning procedure.
Interested to hear the result, and maybe post the tuning procedure, would be interesting.eben wrote:Hi, no no tuning yet. I will start the rough tuning this weekend and maybe use a colortune later. This Carb has an interesting tuning procedure.
- Site Admin
It involves odd-sized allen keys, a ballpoint pen, running the engine at 2000rpm, adjusting the position of the butterfly on the shaft for max intake vacuum and running the engine at full throttle for peak power delivery.
