No more buggy,,,,, now a bug
Farhaad
Re: LCOP TT.............My buggy "build"
Post by Farhaad »
side view
Image[/quote]
i thought my eyes were failing me when i noticed the slots of the front wheel is square compared the rear that is round:lol: .
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
nothing wrong there with your eyes,the 1 is square and the other 3 are rounded :zhelp: :zhelp:
Well seeing that the pan i had was very vrot ,I bought a complete baja minus engine from an ex forum member [luke].
stripped the baja there in his yard and only took what i needed or could resell again
the pan was in a good condition with just a rust hole under the battery area the size of a r5 coin
removed all the tarboard from the floors and the youngest was more than willing to lend a hand
As the shell was already green i decided to spray the chassis hammerite green on top
buggyfan
Long Block
Post by buggyfan »
Greenbean supplied me with a set of highback fibreglass seats :hangloose: :hangloose: all i had to do was modify beetle seat bases to make the work
checking for clearance above my head so that im not higher than the rollbar or windshieldframe
after driving it for a while now ,ive realised that the seats are too far laid back ,i have to drive with my arms nearly fully extended so next on the to do list will be to lift the rear of the seats to more of an upright driving position
buggyfan
Long Block
Post by buggyfan »
just some random pics
front
rear
inside/dash
buggyfan
Long Block
Post by buggyfan »
Now that the Green&gold oval*** has developed a gearbox issue and the better half repo'd the blue oval***,i had to pul the buggy out of the garage and use it to drive up and down
*** does not refer to vw oval at all, :lol:
The buggy will be your best 4x2xfar!
buggyfan
Long Block
Post by buggyfan »
went playing in the veld :hangloose:
buggyfan
Long Block
Post by buggyfan »
buggyfan
Long Block
Post by buggyfan »
Looking good, Jaco! :hangloose:
buggyfan wrote:Now that the Green&gold oval*** has developed a gearbox issue....
I was wondering about that one - an Amstel, with a gearbox issue?? :lol:
buggyfan
Long Block
Post by buggyfan »
Pine wrote:Looking good, Jaco! :hangloose:
Image[/quote
:drunks: ROFL :drunks:
buggyfan
Long Block
Post by buggyfan »
buggyfan wrote:Now that the Green&gold oval*** has developed a gearbox issue and the better half repo'd the blue oval***,i had to pul the buggy out of the garage and use it to drive up and down
reverse idler gear on the Freelander broke a couple of teeth,made for an interesting sound when reversing
buggyfan
Long Block
Post by buggyfan »
ToyIng with the idea of converting this back to a Baja/open top or closed top /as i dont feel comfortable with the idea of 2 kids on the back'seat with no real form of protection aeound or above them whatsoever
buggyfan
Long Block
Post by buggyfan »
Ok,heres the plan ,im going to cut the rear seating area out of the buggy and replace it with a beetle rear section
so that i can get my back seats more forward and lower inside the car .
this is how it sits currently
im trying to get this effect
or do something like this ,
buggyfan
Long Block
Post by buggyfan »
And the cutting has begun :hangloose:
started with his
the rear profile of the buggy and a beetle is too different so i had to trim it some more
the 1st cut is always the hardest to make,but once that grinder started cutting ,theresb no more turning back now
