Warwicks Split
Warwick-Lowlight
Re: Warwicks Split
Post by Warwick-Lowlight »
Well after the stuggle to get that link loose the rest was a dream
Front out
By lowlightwarwick at 2012-07-26
and got the box and shafts out
seems like a bit of a leak in the housing as when I put it face down for some cleaning oil pissed out from behind the release bearing
hope its just a seal that fits in from that side
Box number
Warwick-Lowlight
Re: Warwicks Split
Well after the Jeyes fluid revolution - there has been some major cleaning happening
Front cab area before - during the soak and then the finished work after some high pressure washing
Before
By lowlightwarwick at 2012-08-01
During
After
From the front
Still some elbow grease needed in some areas but Iam generally happy with the result
Other progress at this stage is front axle stripping
Seems all links and kings are fine only need to replace some of the rubbers
tie rod ends all shot
Drag link seems to be good
Centre pin bushing needs to be done
Brakes - look good will get into the slaves and check the rubbers
THERE MUST BE A PLACE THAT ONE CAN GET REPLACEMENT PARTS
Bearings looking good - rear seal was loose on the left side and there is a bit of damage to the slave link pipes
:hangloose:
Been thanked: 21 times
Re: Warwicks Split
Post by Ron&Gill »
FFR... Dave got all the parts for Gill's front end rebuild.
Warwick-Lowlight
Re: Warwicks Split
Shot Ron
Seems GS also has some pieces for me
Warwick-Lowlight
Re: Warwicks Split
Well you just gotta love these German dudes
Took out the steering box this morning and found at tag
will post up pic when camera is charged
would assume that the box has never been tampered with
All is fine with the box just a wee bit of play that should set back to spec
52 years and still strong !!
Should send back to the factory
Maybe they have a better one :lol:
Warwick-Lowlight
Re: Warwicks Split
hre the pic
Ho forgot - unit obviousley still full of good clean oil !!!
:hangloose:
Warwick-Lowlight
Re: Warwicks Split
By lowlightwarwick at 2012-08-05
Did a bit of cleaning in here
seems the seal behind the release beering is poked
Other things being done
Wiper spindles
Brake lines rear
Bit of bashing on the bent up headlight chromes
Trying to clean all the boxes that seem to be filling the work zone
:hangloose:
Warwick-Lowlight
Re: Warwicks Split
And those of you guesing out there
Its power parrafin in the box
Will get the Jeyes out later
Ha Ha
Warwick-Lowlight
Re: Warwicks Split
http://www.aircooledvwsa.co.za/viewtopi ... =4&t=25723
Got that one under wraps
Also found at the junk heap where two wiper arms from a Datsun
Like the look of them and they should polish up nicely
idea here is to fill the hole with a stainless threaded dome nut
This dome nut will have a 6 mm hole in the centre of it to take the wiper spindle
Then a grub srew will tighten up onto the spindle
Might need to do some adjusting on the arm length as when in position without the blades it just touches the side of the frame
By lowlightwarwick at 2012-08-06
This is the hole that will need filling
Warwick-Lowlight
Re: Warwicks Split
Warwick-Lowlight
Re: Warwicks Split
Thanks Paul for the pics
This means the wiper arm needs to be somehow like this
Does this mean that the blade only cleans a V on the window ??
Warwick-Lowlight
Re: Warwicks Split
Cleaning out the shed again
Front bench was about to be loaded to go for some work when I noticed the two tabs at the rear to hold the top portion in place were seriousely rusted
By lowlightwarwick at 2012-08-07
Found an old wheelbarrow that had the same profile bends
Repaired
so dont throw away your barrows lads - you never know when you might need them
Got the seal kit for the reduction boxes from GS
Centre pin and bushes back from engerneers - see networking
Warwick-Lowlight
Re: Warwicks Split
maybe this should be in the seat covers section - just for womens day :hangloose:
cant wait to get this covered as the barrow repairs worked wonders
Still a little bit to do before I'm sitting there going down the road
By lowlightwarwick at 2012-08-08
Has thanked: 425 times
Been thanked: 543 times
Re: Warwicks Split
SORRY, should you decide to cover that there Seats, :shock:
you would not be allowed to place photos of the covered seat on this forum. :roll:
ALL seat covers where removed from this Forum, to prevent a R18 rating.
All our seats look like that NOW !
:TIC: :wink:
:lol: :lol:
Warwick-Lowlight
Re: Warwicks Split
Well we will just have them looking like dat then :lol:
Got a little box of tricks from our favourite green supplier
Thanks Splitbusaholic
Now the real work begins
What did he say again about A pillar meets inner :?
Where did I put that mig welder
Can see this is going to be a wee bit of gnashing of teeth and a few #%^^$###%$%^&$ words
wish me luck as I enter the new reality
By lowlightwarwick at 2012-08-09
