What wrong with this picture ??
Warwick-Lowlight
Post by Warwick-Lowlight »
So in my haste to get pics of my bearings in situ up on the forum I did this
Those of you in the know or who have done the same please spot the problem
This lessson might save you %$^^^$&$^&$ up the new bearings
By lowlightwarwick at 2012-08-12
Leeson 1n reduction box repairs
:hangloose:
Has thanked: 425 times
Been thanked: 543 times
Re: What wrong with this picture ??
At least you do not have to cut the small bearing off :shock: , it should slid off..... :roll:
Been thanked: 21 times
Post by Ron&Gill »
Oh, I was supposed to post it here... the small bearing goes on "heel laaste"... But by the way, you need to press home the 3606 bearing all the way before putting in the main shaft.
Warwick-Lowlight
Welded some blue steel onto the big one on the outside to get the ^#%##%#%&& er off the first time
That was boere taktic as a puller :lol:
Come on okes whats wrong here !!!
If you have done this yourself without the manaul you will know exactly whats FOUT
@ Herman
ya it will - just remove the circlip
Warwick-Lowlight
Ya Rons the winner of a beer at the whales and wheels
If you put on the smaller bearing first then the teeth will not pass the bearing
So main bearing first seated all the way in then the shaft
Followed by the teeth of the smaller gear
then the smaller bearing
and last the circlip
Then you good fr another 50 years or so
:hangloose:
Bushpig
Post by Bushpig »
Hey Dude, Don't you have the manual on CD.....The challange to do without manual always wins. :lol: :lol: ask any woman 8)
Post by Ron&Gill »
This is of course not the case on my 1:1 conversion...
Sambabus
Short Block
Has thanked: 39 times
Post by Sambabus »
The focal length on the camara is set incorrectly. It's on autofocus, hence the slight blurring of the image on the extreme left and the image gradually becoming clearer towards the right?
That's it isn't it........hahahaha,......I nailed it. Someone owes me a beer.
Warwick-Lowlight wrote:Welded some blue steel onto the big one on the outside to get the ^#%##%#%&& er off the first time
@ Herman
retrovan wrote:At least you do not have to cut the small bearing off :shock: , it should slid off..... :roll:
:TIC: :TIC:
