hey peeps, i have a 1600TP, standard motor which i would like to get a little more power from. it has standard carb and would like to know if its worth
it getting a new single intake with 36 carb. getting it from flat four racing and so far couple of mates said yes, makes a nice difference.
would like some input and suggestions please.
1600TP - standard carb or single 36
- Been thanked: 98 times
Re: 1600TP - standard carb or single 36
Firstly, run heat risers, then get a decent linkage, then a air filter that is going to fit the 36 DCD under the fibre glass, then the fun & games strarts. Jetting is ...... anyway, not cheap trial & error good luck
it should make a difference if properly setup. If its the DCD carb kit, then it needs plenty work and can be a bitch to tune properly.
Is your exhaust a 4-1 or a zoom tube style?
- pangolie
- Has thanked: 3 times
well, after fitment it will be towed to jesse hugged in paarl and properly put on dyno and correctly jetted. yes, it has a 4into1 cowley exhaust.
76 kango beach Buggy
89 Caddy bakkie
99 Polo Playa 2.0 tech
89 Caddy bakkie
- Edmond
- Has thanked: 22 times
- Been thanked: 39 times
I think pangolie is referring to the single 36 Dellorto or Weber downdraught carb kit that Dave at FFR sells, if that's the case I think it will definitely be a step up from stock plus the kit comes with the correct linkage, air filter and the manifold equipped with heat risers(you really need them on a single carb like calooker says).
Jetting should not be a problem if you get Jess Hugget to sort it out for you, Dave might even have them prejetted close enough for your 1600 engine.
Don't forget you will need a 009 distributor to suit the new carb.
- pangolie
thanx edmond. yes thats the one. dave said he jets them almost correctly for my setup ,and he knows what hes doing. Jesse can just do the final adjustments to make it run smooth. Dave said i will be looking at about 16hp difference in power, and i think thats just what she needs. im geeting the 009 distr as well yes
89 Caddy bakkie
89 Caddy bakkie
- forcecooled
- Single Port
- Been thanked: 5 times
WOW
33.3% horsepower increase from fitting a single 36mm carb!
Why do we bother with cams, fancy cranks, serious heads and all the other gofaster stuff if thats the kind of power you get from a carb change.
Wonder if you 66.6% increase if you fit two of these carbs?
