Overhauling South Africa
- IMPI
- Been thanked: 78 times
Re: Overhauling South Africa
Watch this for comments on pre painting and post painting welding
http://www.garagejournal.com/forum/show ... hp?t=53534
I wish I had these skills
- IMPI
Finally the thing is clean and bodywork is starting.
Bare ass naked Bug!
Hopefully we show real progress now
Bare ass naked Bug!
- Junior
- Pushrod
Yoh!!!!!!!!
Your work is so good!!! I can't wait to see it when your done!!!
- Has thanked: 424 times
- Been thanked: 542 times
Well done.
Always the hardest part, getting the layers of old paint off, thinking should I just rub it down or take it to metal.
Knowing full well, that should you rub it down, it will badly react with the new paint, then you got to start again anyway.
This will be one fine bug when done.
- IMPI
Another few shots finally the main shell is in primer now for fenders and stuff
- MarshallGTi
- Camshaft
- Has thanked: 7 times
- Been thanked: 11 times
u fitted the bonnet and decklid?
Ryan Marshall
- IMPI
The bonnet and bootlid is off and onn a lot of times to check alignment and curvature. Once all the rough work is finished we will spray hinges and fit them and the bonnet finally just before final paint this way you get a coat of paint in all the nooks and crannies but also over the whole car. It is almost impossible to do the fenders without solidly bolting them on
- IMPI
Hi Renier has just strted uni and the bug is still a bit off but we hope to finish it this year.
December was spent on the pan.
holed bit replaced with section from volkspares
Seams sealed with poly urethane
Then onto stone chip
Front beam needed love
New insert made
Then assembly
all the galvanised bits
some colour
front brakes
Thanks for looking
New insert made
Then assembly
some colour
front brakes
Thanks for looking
Well done, it may be happening slowly, but boy, is it looking good.
I always find its the satisfaction of me my self knowing its a job well done that makes the car so much more enjoyable to drive and enjoy.
Keep it up
Keep it up
- MrT
- Flywheel
- Has thanked: 22 times
- Been thanked: 9 times
Nice progress!
- vader
- Has thanked: 9 times
Hard work..
But it pays off...
But it pays off...
- IMPI
Hi some progress to show. Body work is finally done and we are starting to painr hopefully she will be in paint this weekend.
final primer and stonechip under arches
We painted the dash and under bonnet areas first
Thanks for looking
Thanks for looking
