Actualy 2 complete
Well jet again learning as I go
Sand blasting has revealed something
These popout frames are reverseable ie top can be bottom and inside can be outside
After blasting saw that 2 of the latch areas were different
One on the left is brazed on and the other is spot welded
so chose the best other latch one heated it up and took off the latch so now it will be a hinge side
Even managed to get both with a drain hole on the bottom !!!
