Well dip me in chocolate and throw me to the lesbians... I didn't know this...Blitzkrieg wrote:Side marker lights - leave your indicator stalk up or down when you park your car and see what happens. It's magic I tell youbeetlepower wrote:Afaik they are indicators. What do you think they are?
Project XXXX - 1967 Volkswagen Type 3 Variant (Squareback)
- Ron&Gill
- Been thanked: 21 times
Re: Project XXXX - 1967 Volkswagen Type 3 Variant (Squarebac
Neuk
- What model do you have?: A few...
No real news other than she is going back to Tony to have a new clutch fitted, the thrust bearing whines every time I depress the clutch. Other than that she runs very well, starts up after a few swings and idles pretty well...
Nic
Current:
Daily Drive: 2005 Audi B6 A4 Avant
Project Fes: 1982 VW Golf GLS
Project FeO: 1966 VW Type 2 Kombi
Project XXXX: 1967 VW Type 3 Variant
Previous:
Project Betty: 2005 VW Polo Sportline
Weekend Warrior: 1993 VW Caddy 2.0 16v ABF on ITB's
Current:
Previous:
- MarshallGTi
- Camshaft
- Has thanked: 7 times
- Been thanked: 11 times
and the splitty?
and the splitty?
and the splitty?
and the splitty?
and the splitty?
and the splitty?
and the splitty?
and the splitty?
and the splitty?
and the splitty?
and the splitty?
Ryan Marshall
Neuk
We cleaned the garage it is in...
Nic
Current:
Previous:
Current:
Previous:
Neuk
A few snaps from today, Stu took one of me rolling along the highway and the other I took from inside her...
Her clutch will be sorted this coming week and hopefully a little oil leak...
Nic
Current:
Previous:
Current:
Previous:
- Been thanked: 541 times
Well done, Nice to see another Type 3 back on the road.Neuk wrote:A few snaps from today, Stu took one of me rolling along the highway and the other I took from inside her...
Neuk
Thanks Hermanretrovan wrote:Well done, Nice to see another Type 3 back on the road.Neuk wrote:A few snaps from today, Stu took one of me rolling along the highway and the other I took from inside her...
*pic snip*
Nic
Current:
Previous:
Current:
Previous:
Neuk
So, good and bad news...
Good News - Clutch has been sorted with a new clutch plate, pressure plate, skimmed flywheel, clutch release bearing, clutch fork, flywheel oil seal, etc. It is about a brazillion times better than before and looking at the old clutch parts you can see why. I'll get some pictures up later but the pressure plate was rusted and most likely seized, the release bearing used to be a bearing but now resembles a small grinder, the clutch fork is bent, oil seals are fooked while the clutch itself wasn't too bad. Lesson learnt, on an old car such as this that has stood for quite some time, just replace the clutch as its a relatively simple and inexpensive job...
Bad News - She is leaking oil, from a number of places and the best will be to give her a bottom end and head rebuild in the future. Its not too bad that I have to leave oven baking tins beneath her but is a concern that I would like to address when I get the money. I know these engines leak a bit and will use more oil than a newer motor but I don't want to risk anything and would prefer her running as close to 100% as possible...
Will get some pictures of her old clutch parts up soon...
Nic
Current:
Previous:
Current:
Previous:
Neuk
A few pictures of the old clutch parts...
And apparently a pressure plate should not look like this...
Nic
Current:
Previous:
Current:
Previous:
Me thinks, you need a trip to Goldwargen,...
.. .. with wallet in hand....
Edit;- Sorry missed a post ..
- MarshallGTi
- Camshaft
AFAIK all the bits have been replaced and the old girl is up and running again already
Ryan Marshall
Neuk
retrovan wrote:Me thinks, you need a trip to Goldwargen,..... .. with wallet in hand....
Edit;- Sorry missed a post ..![]()
As MarshallGTi has said, the following has been replaced...MarshallGTi wrote:AFAIK all the bits have been replaced and the old girl is up and running again already
Clutch fork
Clutch plate
Pressure plate
Clutch release bearing
Flywheel skimmed
Flywheel o-ring
Spigot shaft oil seal
as well as two engine mountings. Picked her up on Saturday and she is driving a lot better now! Next up is to give her engine a good clean and degrease and see where she is leaking oil from...
Nic
Current:
Previous:
Current:
Previous:
Neuk
I must be one lucky sonofabitch...
Took the Variant for a quick drive yesterday afternoon and noticed she was struggling to idle and low on fuel. Popped in to a local Sasol and put R100 in and made my way back home. There was a bit of a fuel smell in the car but I thought nothing of it, old VW's have all sorts of funny smells. Got home and reversed in to my parking bay, got out the Variant and noticed what looked like water on the floor that appeared to come from the Variant...
Well, obviously it couldn't be water so I touched it with my finger and smelt it and realised it was fuel, fcuk! Got a small LED torch out and started crawling under the front of the car to check for leaks but found nothing. Went round the back and found a pool of fuel on the passenger side of the car so I opened her up and opened the engine bay cover. The main fuel line looked fine and I couldn't see any leaks so I started looking around the passenger side carb...
The man fuel line to the carb was loose and I am pretty sure is the cause of the fuel leak. Having heard and seen pictures of horror stories of aircooled VW's setting themselves alight, I grabbed my fire extinguisher that I keep in the Variant, got as much out the car as possible and waited for at least 20 minutes. Luckily nothing came of it but it gave me a fright anyway, we had already removed the fuel filter from the engine bay and relocated it on top of the gearbox, a huge no no! It looks like I am going to need to review the fuel lines from the pump to the carburettors to make sure this doesn't happen again...
Aircooled VW Tool #1 - Fire Extinguisher
Nic
Current:
Previous:
Current:
Previous:
Squareback newbie
- Oil Leak
- What model do you have?: 1967 Squareback
- Been thanked: 5 times
Hey glad it was a minor leak and nothing to hectic ? u going to campfest with her?
Squareback newbie
- Oil Leak
