PARTS LEFTOVER FROM RECENT CLEARANCE
Get your parts here
HERBy
What model do you have?: 1600
Post by HERBy »
DISTRIBUTOR (Early type. Short body with ring clamp. Complete with cap, rotor, points and condensor) R100
WINDSCREEN WIPER ASSY WITH MOTOR - R100
(motor was good when assembly removed))
3 X FUEL PUMPS R50 THE LOT
CLUTCH RELEASE BEARING PARTIALLY USED - R30
FLYWHEEL GLAND NUT AND SHIMS - R30
SOME ENGINE SHROUD PIECES - R20
CLYMER BEETLE WORKSHOP MANUAL R 40 ]- SOLD
OR TAKE EVERYTHING FOR R350 ]Let me have your email and pictures will be sent
Retro13
What model do you have?: Kestrel Buggy
Has thanked: 7 times
Re: PARTS LEFTOVER FROM RECENT CLEARANCE
Post by Retro13 »
PM Sent...
Never ride faster than your guardian angel can fly...
Riekert
Camshaft
Has thanked: 111 times
Been thanked: 23 times
Post by Riekert »
Will the flywheel nut work on a type 3 engine?
HERBy
Post by HERBy »
Rekert wrote:Will the flywheel nut work on a type 3 engine?
Had no eperience of working on type 3 although used to own a magnificent Variant. As far as I know the earliest editions (about 1961) were based on the Beetle 1200cc which itself was the basis of the subsequent 1300cc and 1600cc versions T1 and T2. The T3 apparently has a similar transmission set-up although the geometrics were different. But all this still means I don't know although logic might say it should fit. Its not that expensive so can always take a chance and resell if it doesn't fit. (I'm sure you know how much these cost new).
Hope that helps, a bit.
Bob
Riekert
Camshaft
Post by Riekert »
Hehe thanx! Then I'll take it
HERBy
Post by HERBy »
Rekert wrote:Hehe thanx! Then I'll take it
OK no problem. If you want to let me have your email and cell number then can fix up a plan and give directions by SMS. Maybe would be economical to pop it into a jiffy bag and mail to you if you do not want to come through to Kyalami. You can just do a EFT or something - no matter, whichever way you are most comfortable just let me know.
Sincerely,
Retro13
Post by Retro13 »
Hi Bob
It was great to meet you last night and exchange stories :) . Many thanks for all the parts, they'll definitely come in handy with the rebuild.
All the best in your future endeavours.
T!M
HERBy
Post by HERBy »
Retro13 wrote:Hi Bob
T!M
You're welcome. Hope the rebuild goes well. If you give me a PO Box address will pop a copy of the John Muir VW engine sounds CD in the mail.
All the best.
Bob
Riekert
Camshaft
Post by Riekert »
Sincerely,
I've completely forgotted about this:shock:
Do you still have the bolt? If so please let me know.
HERBy
Post by HERBy »
Sincerely,
Hi,
So sorry but it went last Friday. All the Beetle parts are now sold out. Only got Jetta 2 carburettor and Golf 1 carburettor and choke cable left.
Bob
Riekert
Camshaft
Post by Riekert »
Damn! All good
