Running on Unleaded
natbro
Running on Unleaded
Post by natbro »
Hi Guys,
What is needed to convert a type 1 engine to run on unleaded? Is it quite costly? Is it even possible? :?
vuyo
Facebook: vuyo dube
Post by vuyo »
pm calooker i think he has unleaded heads
60s look 74 beetle
skype: afronotch
Matliam
What model do you have?: 1975 Beetle
Post by Matliam »
With the older technology used in the aircooled engine it should be able to run on unleaded without problems.
This is an extra from the same question ask on the Association of British Volkswagens Club:
"The bottom line is that you could run on un-leaded without undue concern.
When your VW was new it was advised that
"The Volkswagen will run satisfactorily on all normal commercial fuels which fulfil the octane requirements of the engine(91 octane)."
When unleaded first became available VW recommended that for every four tankfulls of petrol, one should be leaded to maintain the lubrication.
I am not aware of anyone having any issues with running on unleaded and have done so since leaded disappeared from general circulation.
There is an excellent page put out by VW Beetle tuner John Maher.
http://www.johnmaherracing.co.uk/technotes_fuel.htm"
This was asked about a '64 Beetle.
It's only the heads that are a concern with unleaded - valve guides and seats; to the best of my knowledge.
Been thanked: 98 times
Portugal
Post by calooker »
I have run a couple of tank fulls of 95 unleaded in my Spyder, no problem yet, I don't drive it much probably only done about 500 km's we will see in the long run, I also didn't notice any diff in perfomance going from 93 LRP to 95 unleaded.
Been thanked: 321 times
I suspect that our more extreme driving conditions would more likely show up unleaded-induced problems.
Having said that, however, I have had no problems with my daily driver Fleetline panel (1600TP) using LRP. I have been keeping an eye out for signs of valve seat recession, but no issues so far. I drive this bus every day, and have driven it on LRP on several long road trips, including a 5,000km round trip from Jhb to Cape Town.
I have heard that later AVCVW engines had hardened valve seats, and that early engines may have problems, but I have no experience of this.
I think LRP works well for ACVWs. We may have a problem when that is phased out and only true unleaded is available.
