DIY Powder Coating supply's, no more, but Ind. plants
Get your parts here
Has thanked: 425 times
Been thanked: 543 times
Hi Guys,
Edited;- Do not make DIY systems anymore, due to lack of interest, do how ever still build industrial plants on "Turn-Key" basis.
Not many know that I not only manufacture Heavy Duty Trailers, but also design and build Powder coating and wet spray plants.
I have been asked by a discount tool distributor to make a Mini DIY home curing oven for the Baking of Powder coating.
It is 800 mm by 800 mm by 800 mm so can easy fit big rims into it.
So now I can offer this equipment to you the forum guys, and also be the 1st in South Africa to sell you only 1KG bottles of powder coating powder, this is normally only available in 20 Kg boxes, and who can afford to pay for 20 Kg if you only need 1 or 2 kilos.
So many colour, is now possible, and can be shipped to you by courier or parcel post
We can therefore supply you with a Powder spray gun, as well as Curing Oven and also the powder.
Here are some of these photo's
PM me for more info
Re: DIY Powder Coating supply's right here
Squire , what temp's does that oven run at??
Hi HR, the oven at this moment will top out at 280 Deg. C
But can be set higher with different controller, will then run to 450 Deg. C ( insulation value)
My powder will cure from 160 to 180 Deg. C but other makes need to run at 220 Deg. C
If you need one for Ceramics, let me know, I can build you one to go to 1400 Deg. C ( insulation value)
Ceramics ovens run from 660 to 1280 Deg. C if my memory serves me right.
piesang
Post by piesang »
Cool , or shell I say hot!!
So one will be able to buy the powder at the Adendorf shop nearby?
piesang wrote:Cool , or shell I say hot!!
Not all will carry it, you may have to ask for it, BUT, you can always get it from me, direct.
they may not get many colours ether, but I will have them all.
piesang
Post by piesang »
ok
riaanj
Been thanked: 41 times
Post by riaanj »
Sweet! pricing on the oven and the 1kg powders?
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
4agedub
Been thanked: 13 times
Post by 4agedub »
Can you please pm me some pricing as well.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
GTW
Post by GTW »
Hi. Can you tell me what your 2kg powders cost and also your ovens? Also where can I buy a diy good quality gun?
You will probably need the same electrical supply as to your kitchen oven or does it run on 3 phase?
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Hi Herman pls can you tell us what we need to do powder coating at home and what you can supply.
Thanks.
Hi Guys,
Well the DIY system was developed for Ardendorffs, as they imported a DIY gun and we where going to supply the oven and powder.
The oven runs off 220 v AC ie from your normal plug, and heats up in approx. 15 min.
As I have not costed the parts of late, I can not tell you the cost of building an oven now days.
The high cost is in the high temp insulation.
So unless you use the oven for more then DIY, it will be cheaper to have your stuff done by a Powder coater.
Terry Phillips
Zambia
Thanks Herman,intresting to see the development of the unit.
shaunart74
What model do you have?: 1970
Post by shaunart74 »
Please email me a price list.
consumerzone1@gmail.com
Thanks so much
Shaun
0725088935
Have stopped this in June last year due to lack of interest in the market place.
So sorry , can not help you.
