Hi guys, I have two complete motors for sale, one running very nicely but leaks oil, I suspect cracked enjin case, other motor has bearing knock complete with carbs, alternators (one is brand new), cooling shrouds, distributors, exhausts etc. will also sell parts seperately
R6000 for the lot or make an offer for what you need
1600 tp motor parts
- ValieVW
- Oil Leak
- What model do you have?: 74 Bus
- Has thanked: 8 times
Re: 1600 tp motor parts
I have:
2 x Pict34 3 carbs with new kits on - R700 each
2 x Alternators with cooling shrouds (1 with internal regulator and one with external) - R900 each
3 x heads in good condition - R500 each
1 x head needs helicoil - R200
2 x distributors with caps - R400 each
2 x Cooling tin R800 for the set
1 x flywheel - R400
2 x engine cases with sleeves, pistons and cranks - R600 each
1 x 4 in one exhaust - R500
1 x standard beetle exhaust - R500
4 x J - pipes - R100 each
1 x crank pulley - R200
or make an offer for bulk.
1 x flywheel - R400
- beetlefocus
- Oil Leak
- What model do you have?: 1977 beetle1600l
- Koekiecup
Good Day ValieVW
Hope you are well.
Could you kindly advise if the 1600 tp heads are still available?
Thank you
Koekiecup
Hope you are well.
Thank you
Koekiecup
Noodles
- What model do you have?: Beetle S
Have you got a carb for me?
1974 Super Beetle 1600
2007 Volvo S40
2007 GSXR 750
Rippa 125 pitbike
2007 Volvo S40
2007 GSXR 750
Rippa 125 pitbike
