chrisradioman
Post by chrisradioman »
chrisradioman
The guys at Custom Classics have decided to repaint the van as the seams aren't perfect, the finish is perfect with no runs:-
While the boys were keying in the whole van again I worked on the pop top:-
Cleaned all the old flock off:-
chrisradioman
chrisradioman
Doors & panels are now painted:-
I'll get some pictures of them finished later.
chrisradioman
Started to strip my trailer:-
chrisradioman
All the doors are now done:-
Started taking the masking off Milly:-
I started putting the doors back on:-
So far the tailgate & both front doors are on:-
chrisradioman
Meanwhile the pop top is now all painted:-
The inside of the rear pop top was painted while the front was painted:-
There is a huge difference with the L90D pastel white & the non VW white that it was painted in:-
chrisradioman
chrisradioman
chrisradioman
The sliding door is now built up ready for re-fitting:-
Engine lid ready for re-fitting:-
Headlights re-fitted:-
Back lights re-fitted:-
chrisradioman
Sprayed inside all the panels with Dinetrol:-
Mean while the boys have been cutting & polishing the van:-
Tailgate seal on:-
Sliding door & seal on:-
Fitted my chrome U-bolt:-
Door handle & seals fitted:-
chrisradioman
All the catches have been chromed & fitted:-
Zinc plated door check straps:-
Look at the shine on that:-
Put Dinetrol around the window aperture to stop any future rust:-
Bolted on the brackets with sealer to stop any possible water ingress:-
Front screen in & front of pop top on:-
chrisradioman
Continued the build up today. Put Dinetrol cavity wax in all the panels:-
Greased up the sliding door tracks:-
Stuck on my engine hatch seal:-
Fitted the passenger door rubber:-
chrisradioman
Fitted one of the Westy windows:-
& the inner seal:-
Fitted the engine lid seal:-
Fitted some interior parts:-
Refitted the Westy cupboard:-
The aerial, mirror & washer jets:-
chrisradioman
Continued with the build up today. My sliding door mech is now in properly:-
RHS door is nearly finished:-
A few roof parts fitted:-
Started doing the deluxe trim:-
