VW Kombi/Transporter Project Help
bakes
What model do you have?: VW TRANSPORTER
Re: VW Kombi/Transporter Project Help
Post by bakes »
Hi Ricky
You 100% Correct we checked while working on it this weekend and putting the alternator back in and it is a 2.0L Motor Air Cooled :D
Just the Brakes Getting done today and we are 100% Mechanically SOund, Also put Side panneling on the inside the weekend, Next up Carpeting and then Seats :mrgreen:
Thanks!
1982 VW TransPorter 2.0 Aircooled
1982 BMW 518i (Auto)
bakes
Post by bakes »
Hi Guys
I need Your Help urgently
Just been Hit with a R2890 Quote for the Rear Brakes as the Drums have been skiimed so many times they cannot be skimmed anymore, So need a set of new Drums at R1200 as well as Cylinders as they are leaking :cry: and the Pads are R900, anyone know a place to get Good Second had Drum brakes or even new ones for cheaper then R1200?
Im in Port Elizabeth
Your Help will be Greatly appreciated
Muderick
Has thanked: 42 times
Been thanked: 69 times
Post by Muderick »
:lol: Welcome to the club Bakes...
And there you thought it was gonna be CHEAP and simple?
Dont worry, some of the PE guys will be able to help when they wake up later.... :lol:
Muds
Old School or Bust!
Has thanked: 425 times
Been thanked: 543 times
bakes wrote:Hi Guys
Sorry, only woke up now.....was a bit early for me....Had "Muds" in my eye.. :lol:
You can get these things from the VW Bus guy in Hunters Retreat, carry s a lot of 2nd hand parts for buses.
You need to start trawling through the scrapyards asap, start asking around, keep a photo of a bay window bus in your wallet and ask everyone if they know where similar scrap busses are lying, in backyards, scrapyards, informal settlements, industrial areas. Start scavenging - the more bits you can save, the more you can use and trade with .....
So Speaks a wise Man....
With the Fastback, had the same problem
Went to Brake Centre, told the guy that if he skims my drums, he is dead.
All he did was hone it with flatting paper, rebuild my shoes, and for less then R500 I had perfect brakes.
You do not have to skim the drums every time, even if they not lekker flat, or have groves in them, the shoe will wear to match the drum, and it will work perfect, if not better. (more surface area)
They want to skim drums, as it ensures them income, and full brake function from the start. so you have to be careful till they run in, but hey, some emergency braking on a quite road, and they seated. You have to do that anyway to get confidence that the breaks work anyway, well I do.
OMO
bakes
Post by bakes »
Thanks[/quote]
Herman[/quote]
Thanks Herman you wouldnt happen to have a number or address for this guy?
The Shoes where put in incorrectly last time by whoever put them in so they started wearing skew and then damaged the Drums in the Process at whch they at the point they need to be skimmed but you can't skim them as they are at there max :shock: You Just never win lmao :lol:
Thanks for all the Help Guys
bakes
Post by bakes »
Hey Guys everything going great all coming together nicely will post pics soon.
Added Corner couch type Seats
Panelled and Carpeted sides
Got all Mechanics working 100% and new brakes new Tyres
But I have hit a Hiccup once again the Fuel gauge is not working need a new sender unit tahts in the tank anyone know here I can get one? Vw Transporter T3 1982
Phoned all Around PE with no luck :|
bakes wrote:.........
What I do in a situation like that, I phone Goldwargen, Beetle Shop, Volkspares, and all the normal suppliers, and ask what other car senders are the same or compatible, and then hunt for those, no manufacturer, can warrant having a one off part, they mostly use a common part for something like that.
OMO
MrT
Has thanked: 22 times
Been thanked: 9 times
Post by MrT »
bakes
Post by bakes »
Thanks For all YOur Help Guys
Sourced one at Volkspares for R450
Back on Track :D
bakes
Post by bakes »
Here some Pics For you Guys :hangloose:
Before
After
More To Follow Just need to get them Uploaded :D
bakes
Post by bakes »
MORE PICS TAKING JUST BEFORE A ROADTRIP TO NATURES VALLEY :D
Oh you lucky buggers, Natures Valley is so cool - looking very cosy in there ! Drive safely and don't forget to take photos !!!
bakes
Post by bakes »
Hey Guys need Some help Again
Gearbox Gave Some troubles over the Weekend, Jumped out and Lost all Gears was like Moving a Stick in a Bucket of Water :shock:
Anyway Got Underneath Re adjusted it and Tightened it looks like the Shifter came loose anyway, I cant Seem to Find the Gearbox Oil Drain Hole OR Top Up Area? Can anyone Point me in the Right Direction please :lol:
