How esentual is it?
Roly
What model do you have?: KOMBI
How esentual is it?
Post by Roly »
When stripping a running beetle engine for replacing main bearings, would i need a reline bore?
Re: How esentual is it?
How bad is your forward back play in your crank ??? when pulling on the pulley.
Roly
Post by Roly »
Very little! If u can call approx 1 or 2mm max little?
Edmond
Has thanked: 22 times
Been thanked: 39 times
Post by Edmond »
Max spec on crank endplay is 0.15mm.
easy way to check if a line bore is rqd is to see if there are ridges pounded into the case main bearing saddles, if you can catch the ridge with your fingernail it's linebore time.
If the end play is excessive you need the thrust saddle recut and a matching bearing machined to fit the recut thrust saddles.
Roly
Post by Roly »
Tks Ed. I appreciate ur advice. Will check & be stripping soon.
Tks again.
