Difflock
- JohnCloete
- What model do you have?: 1966 Type 3 SquareBa
- Has thanked: 42 times
- Been thanked: 4 times
Difflock
I know I ask plenty questions, and sometimes you guy's might just think I am a moron....... but here is another one
Can Difflock be fitted to a '79 bus gearbox
John
0734897477
. . . . . . . . . . . . . . . . . . . . .JESUS IS LORD OF ALL
0734897477
- Sambabus
- Short Block
- Has thanked: 39 times
- Been thanked: 14 times
Re: Difflock
..........moron.
- JohnCloete
Re: Difflock
................No Kidding!!!!
John
0734897477
0734897477
- Sambabus
- Short Block
Re: Difflock
hahahahahaha, call Bugger from Buggers transmissions. He has a banner add on the forum. Also, try private message him.
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Re: Difflock
Limited slip diffs were always available as an option on ACVWs, under M220.
I don't know whether modern, aftermarket locking diffs can be fitted to ACVWs. I've always been told no when I asked locking diff suppliers, but I don't think they really knew.
- JohnCloete
Re: Difflock
ThanX guy's, will be talking to Pierre soon, will let you know the verdict
John
0734897477
0734897477
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Re: Difflock
The problem will be the center portion of the gearbox where the diff goes. The center portion needs a casting where the difflock actuator shaft needs to enter into the diff section adn obviously where the actuator is mounted. The second problem might be finding a locking diff for a bay window. I think there is an American company doing al sorts of stronger gears and lockers for T3 busses, but they also had stuff for T2 busses. Ican't remember if it included locking diffs for T2s.
Bugger has the center section of a Syncro box with the standard microbus gears fitted. This gives nice ratios for cruising and difflock option when needed. You could always fit a Syncro gearbox but then you need to modify the shifter linkgages. I'm still toying with that idea myself. Oh, and the other problem with that is to find a good secondhand Syncro box. I paid R22k for an exchange unit from Erlemans last year. Secondhand ones don't come up for sale often and then you can expect to pay anything from R10k to R17k.
- JohnCloete
Re: Difflock
ThanX for the info, so .........????
Can a complete syncro system be fitted to a bay window? Just asking, sounds like syncro parts will cost an arm and an a leg
John
0734897477
0734897477
Re: Difflock
What might be a cheaper alternative (and a bit of a challenge to get right in a Bus) is a dual hand brake lever system. When one of your wheels gets stuck in sand/mud/snow you will find the other (loose) wheel spinning. If you are able to brake that wheel on its own, the power will be transferred to the stuck wheel, and should help to get you out. This was a popular modification for off-road VWs in earlier years.
- Been thanked: 541 times
Re: Difflock
Saw a Twin Handbrake lever system on the Samba the other day as an after market part, was sold by an overseas performance site.
Will see if I can find it again.
- JohnCloete
Re: Difflock
ThanX Pine, sounds xcellent. Herman, much appreciated man
John
0734897477
0734897477
- Has thanked: 18 times
- Been thanked: 58 times
Re: Difflock
Yip as Beetlefanatic said I do have built a 2wd box with Lockable diff for my Doka but it did cost alot even for myself and that is why it is nod done regularly
If I have to build a 2WD lockable Bay window box then the bigest challange will be to find the machine shop that will machine the side of the casing
but I might be able to over come that hurdle
and I have found a post on the net where a bay have been made lockable and I did steel with the Eyes and got alot of info so it seems do able making it work with a Cable from the driver chair
- JohnCloete
Re: Difflock
ThanX Pierre, did call today on your cell and then spoke to Johan at the shop
Will call again tomorow
John
0734897477
0734897477
- fig
- Bus Driver
Re: Difflock
Re Pine's suggested double handbrake mod: whenever I have a wheel spin on one of my buses, I progressively pull on the stock handbrake and that usually slows the spinning wheel enough to get things moving again. Maybe not a locking diff, but it costs nothing and it works for me.
- JohnCloete
Re: Difflock
Was actualy thinking about a steering brake, but your idea sounds just fine
John
0734897477
0734897477
