midmounting a beetle engine ?
vuyo
Facebook: vuyo dube
Post by vuyo »
this ones for Bugger
is it hard to midmount a beetle engine like they have on fomula vees
what do you need to do ?
do you still have the all gears?
cooling problems when running in a beetle?
just want to know
thanks
V
60s look 74 beetle
skype: afronotch
JohnHoffe
Re: midmounting a beetle engine ?
Post by JohnHoffe »
Hey,
A clever dude like Bugger simply turns the diff around inside the gearbox to make it work for mid-mount. All the gears still work the same.
Cheers
Been thanked: 321 times
You would need to replace the pan with a custom space frame chassis to mid mount the engine. Doable, but a lot of work.
JohnHoffe
Post by JohnHoffe »
fig wrote:You would need to replace the pan with a custom space frame chassis to mid mount the engine. Doable, but a lot of work.
I have a set of drawings for a space frame....... :D
All EAsy as Pie :lol: :lol: :lol: :lol: :lol:
$$$$$$$$$$$$$444 is what you need but all doable
Bugger... I've heard about flipping a g'box over a lot... with audi & alfa boxes too. But could you please explain to me what needs to be done to accomplish this? Are special parts needed or is it just a case of turning the orientation of the existing parts?
eben wrote:Bugger... I've heard about flipping a g'box over a lot... with audi & alfa boxes too. But could you please explain to me what needs to be done to accomplish this? Are special parts needed or is it just a case of turning the orientation of the existing parts?
When talking flipping a gbox are you talking specific Beetle of the Audiand Alfa
Beetle you can fit the Diff from the opposite side it usually go in and turn the box around Not flipping it to make it midmount
The others you actually have to turn the Box upside down close vent holes and make new vent holes at the "BOTTOM NOW TOP" and new oil drain hole top now bottom :lol:
Kapiech :?:
Aah so for a beetle g'box you just turn the diff innards around but for the others you need to flip the box.. thanks... was always wondering about that.
Been thanked: 487 times
flip the diff vs flip the box
I know a guy who split his diff when he fell off a mountain bike ;-)
riaanj
Been thanked: 41 times
Post by riaanj »
Tony Z wrote:flip the diff vs flip the box
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
colignym
What model do you have?: Beach buggy
Post by colignym »
If I may ask, if one does a mid mount (I am thinking Spyder replica) then how does one get the gear rod linked up as engine will be in front of gearbox, or am I just being stupid here?
colignym wrote:If I may ask, if one does a mid mount (I am thinking Spyder replica) then how does one get the gear rod linked up as engine will be in front of gearbox, or am I just being stupid here?
I was wondering about that a few years ago as well, till I saw this Formula Vee at a Show in Pretoria in 2007 - had a close look at the linkage setup but *duh!* :oops: didn't take a picture of it!
The linkage did however look something like this - a bit more complex than a standard Beetle but I'm sure you'll figure it out -
colignym
Post by colignym »
Thanks Pine,
That really helps. If I have a 5 cylinder Audi engine, (actually looks like it may fit midmount in spyder) then maybe something like this can be done? Maybe it is an crazy idea, but imagine the nice sound on this little kit car.
Would a beetle suspension be safe enough on such a setup? I am not talking a racing car, or a 200 kph car. I am thinking a nice sounding RSK, with a good 0 - 100 just for fun between robots.
Thanks for the pics
John Alves
Has thanked: 3 times
Been thanked: 48 times
Post by John Alves »
JohnHoffe wrote:I have a set of drawings for a space frame.....
can you post them for all to see??
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
colignym wrote:Thanks Pine,
Thanks for the pics
You can build a custom gear linkage system to make the gears work mid mount
and make a turnd around beetle suspension setup work with the 5cylinder motor you want to use just with some upgrades
