Gadgets and Gizmos
Terry Phillips
- Has thanked: 193 times
- Been thanked: 121 times
Re: Gadgets and Gizmos
I should imagine if you had the real aircon installed on a Beetle you would end going through the windscreen when you push the on button, it would take so much power out of the motor.
Last edited by Terry Phillips on Fri Jul 05, 2013 7:12 pm, edited 1 time in total.
the stock heater take no power to use at all, the heat is on the exhaust already and the engine cooling fan is blowing air just like it always does...
Just a quick Q, whats the difference between the red and the grey heater lever? Is it just left and right? or is the a reason they're two different colours?
Pic of my babe broken down on the side of the road
