Hi.
I hope someone can help me.
I have a 1973 1600 dual port beetle. I had it serviced recently but the problem is still there.
When I start the car it idles fine, but after a few minutes of driving or idling the engine dies, unless i keep the revs up, it doesn;t want to idle. then after a few more minutes the engine runs fine again. Also my fuel consumption seems to be a little bit higher. What is wrong?
I get the feeling it might have to do with the carb or choke.
What is wrong?
- eben
- Site Admin
- Been thanked: 54 times
- Single Port
- Has thanked: 13 times
things to check:
- fuel is coming nicely (fuel line and filters)
- carb is working (idle circuit and jets)
- manifold is sealed (no air leaks)
