Twin Solex Carb Kit for T1
- Been thanked: 98 times
34mm Solex Brosol carb kit from Brazil, all new, everything you need, it's 100% bolt on for T1 motor Bus, Bug, KG.
Exacly the same thing as our SP beetles had just slightly larger 34mm instead of 32mm. R4300
Similar kit is also available for T4 motors 1.7 to 2.0
Rui 082 830 6493
Can ship to anywhere in SA R90
http://aircooledvwaddiction.com/albums/album34/aag.jpg
Rui 082 830 6493
- Sambabus
- Short Block
- Has thanked: 39 times
- Been thanked: 14 times
Re: Twin Solex Carb Kit for T1
Oooh,those are nice!
- Has thanked: 425 times
- Been thanked: 544 times
Hi Cal,calooker wrote:34mm Solex Brosol carb kit from Brazil, all new, everything you need, it's 100% bolt on for T1 motor Bus, Bug, KG.
Rui 082 830 6493
Please measure the carbs for me, want to fit to T4 motor in Fastback body with cover.
Also, tell me what the manifolds are made off, should I want to cut and shorten them for the 2L type 4 motor.
If they are weldable......
The manifolds are ally for both T1 & T4 but the T4 manifolds in the kit will be too long to get the lot under the lid, I have a set of short 1700 T4 manifolds that sure will help but the air filters in the kit are too tall to make it work.
- slak
- Has thanked: 7 times
- Been thanked: 32 times
Please measure the hight of the two, carb & manifold, separate as well as together, and will you split up the kit or not.calooker wrote:The manifolds are ally for both T1 & T4 but the T4 manifolds in the kit will be too long to get the lot under the lid, I have a set of short 1700 T4 manifolds that sure will help but the air filters in the kit are too tall to make it work.
maybe it will work by cutting and welding short manifold, and fitting a different air cleaner.???
- louisvr45
louisvr45 wrote:is it the solex 34 pic3 carbs? Like fleetlines came out with?
No, look at the pic I attached. T4 kit R4500. Sorry can't break up the kit, can't measure manifolds for T4 this kit is T1
- Pharco
- What model do you have?: '69 Type 3 Fastback
Hi Rui,
Do you sell carb rebuild kits for Solex Brosol 32/34 PICT 3? I have two carbs for 1969 Fastback that I want to rebuild but cant find carb kit.
Thanks,
Phillip
Thanks,
Phillip
Do your carbs have 5 or 6 bolts bolting the carb top to base? A pic. will help.
