- Edmond
- Has thanked: 22 times
Adjusted the brakes on my Baja and found out the right rear brake drum was on the verge of coming off, looks like the split pin had sheared, tightened it up with my 1.2m steam pipe and cut 36 ring spanner and all is good again.
Also reset the points gap and the ignition timing, she sounds healthy again.
- Dutch_Diver
I bought them a present......to come to the rescue when they breakdown [FACE WITH STUCK-OUT TONGUE AND WINKING EYE]
- Has thanked: 36 times
- Been thanked: 50 times
gman1034
- What model do you have?: 1974 4age beetle
Removed my fuel tank to be replaced by the fuel cell I shall fetch during the week,
And discovered I have a collapsed rear gabriel shock
Teetle - the toyota powered beetle.
4agte ...KW ...NM
Soon to be completed
4agte ...KW ...NM
- Wentzel
- Has thanked: 6 times
- Been thanked: 13 times
I did some mapping on the EFI and found that traction is becoming a problem more and more in the wet weather so I think I'm going in the right direction ... Will have to work on the traction
Oxyboxer Project
- beetle786
- Camshaft
- What model do you have?: 1968 + 1303
- Tinfontastic
- Oil Leak
- What model do you have?: 1973
Got a donor beetle yesterday. Now for some more work on the body
MELLO YELLOW
- What model do you have?: 71 Bug, 69 Westfalia
Took the four fenders of my "new notch" and treated the under body to some rust tec, also started to dry flat the roof
Cant wait for this rain to stop so that I can clear coat it
- hitlers revenge
- Been thanked: 36 times
Finally got these done. Just need some centre caps.
- Tinfontastic
- Oil Leak
Got my doner body yesterday. Started to strip it. So far it looks good. Was a great buy.
drove 80km without a glitch
- dixtoy
- Has thanked: 60 times
- Been thanked: 37 times
Finely got a chance to fit the electronic ignition
1959 Beetle (Lindor)
1975 Fleetline panel (Ouvrou)
1971 Westy (Gypsy)
1971 Westy (Gypsy)
- beetle786
- Camshaft
What type of distributor do you have on and what type of electronic ignition did you use .
- dixtoy
The dizy is from a 1900 WBX and was fixed to 009 spec by Distributor re manufacturersbeetle786 wrote:What type of distributor do you have on and what type of electronic ignition did you use .
1971 Westy (Gypsy)
1971 Westy (Gypsy)
