- beetle786
- Camshaft
- What model do you have?: 1968 + 1303
- Wentzel
- Has thanked: 6 times
- Been thanked: 13 times
Installed my diy keafer brace and gearbox strap. Hope it will be an noticable difference.
Oxyboxer Project
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
MELLO YELLOW
- What model do you have?: 71 Bug, 69 Westfalia
Well finally the rain has stopped
Friday I dry sanded the last bit on the notch and gave it two coats of clear
Saterday trial fitted the fenders and she does look good (different but good)
And then yesterday I decided to fit the mags that I had on my bug.
It changes the whole appearance
- Has thanked: 36 times
- Been thanked: 50 times
Started re-wiring the dash as well as depleting my bank balance with ordering new stuff.
- Riekert
- Camshaft
- What model do you have?: 1964 Notch
- Has thanked: 111 times
- Been thanked: 23 times
busy with the notch's motor. Took off all the tinware for a respray and giving it a good service while I'm at it.
- John Alves
- Has thanked: 3 times
- Been thanked: 48 times
Set timing on ghia, buggy got brakes adjusted
Both running sweetly now
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
- beetle786
- Camshaft
- 62vwbeetle
- Oil Seal
- Been thanked: 12 times
Managed to get 3 of 4 handles and backing plastics onto doors properly , it's a cow doing it with broken finger, also made up pre 67 style wiper switch using broken ivory door handle and existing switch , looking better. also note to self check power is on when charging battery as back up car for Angela's picnic was still flat. Doh!!!
MELLO YELLOW
My self and a friend sorted out the wiring on the notch this weekend, What a mess
But we managed to sort out all the lights, indicators and dash lights
Now all I have to do is put the carpets back
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
finished my clutch master cyl bracket and links , also got my clutch and flywheel back from ballancing need to make a new bracket for the new fuel pump and then the motor can go back in also got the rebuild turbo back .
- Been thanked: 98 times
Stripped an inlet stud as well as my moer fitting a set of Dellortos to my SC, 30min job turned into a Saturday's frustration, having to fit a insert with the motor in place, no easy task.
MELLO YELLOW
- 62vwbeetle
- Oil Seal
Charged Battery for Porsche ghia and the bug - maybe I can have success on 1out of 3
- Wentzel
Not really today but been driving the Beetle a lot the last week. Quite happy with the drivability she's very fun to drive. Fuel consupmtion to Angelas picnic and back +-300km took 3/4 tank. Around town seems a bit more but hard to tell without filling up again.
Oxyboxer Project
