Spot anything different? - Fleetline engine...
GavinHuart
Has thanked: 48 times
Been thanked: 9 times
Post by GavinHuart »
Hello all!
This is a picture of my rather magnificent Bill-Noble-built Fleetline engine, which a lot of you may have already seen.
There's been a bit of tinkering of late :wink: . Random as it sounds, 10 points to the one who can spot what's "different" about how it appears now (Nic and Pierre, be quiet :wink: )
Gav'
Sambabus
Short Block
Has thanked: 39 times
Re: Spot anything different? - Fleetline engine...
Post by Sambabus »
Fan shroud?
GavinHuart
Kegan, thank you but no cigar I'm afraid. Offer up an image of another 1600TP engine of similar glory...
Alternator is the internally regulated style (ie, not the 75-only 3-prong externally regulated alt)???
Inlet manifold has the vacuum port for a brake booster (ie, from a baywindow bus)???
GavinHuart
fig wrote:Alternator is the internally regulated style (ie, not the 75-only 3-prong externally regulated alt)???
Hmmm. Bugger. I should have known you'd know more about these engines than I. You are correct on both points but they are not what I'm hinting towards I'm afraid. You happy with five points? :wink: '
- It is something else and something not terribly technical :wink:
looks like you might have an electronic dizzy and coil
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Wrong oil pressure light sensor
GavinHuart
Tony Z wrote:looks like you might have an electronic dizzy and coil
Thanks Tony Z. Nope. Stock ignition stuff on this one.
GavinHuart
IMPI wrote:Wrong oil pressure light sensor
Hi IMPI. Is it? :shock: . Not that either :D
dixtoy
Has thanked: 60 times
Been thanked: 37 times
Post by dixtoy »
Heater pipes connected
1959 Beetle (Lindor)
1975 Fleetline panel (Ouvrou)
1971 Westy (Gypsy)
Where is that pipe going from the oil filler cap?? Is that connected to your brake booster????
If so, that's whats different.
Are you boasting about the nice new orignal style paper and foil heater pipes?
hitlers revenge wrote:Where is that pipe going from the oil filler cap?? Is that connected to your brake booster????
That's the crankcase breather, connects to the inlet pipe of the air filter.
GavinHuart wrote:You are correct on both points but they are not what I'm hinting towards I'm afraid. You happy with five points? :wink: '
Each! :wink:
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
No more oil leaks???
