1975 & '79 Bay Busses
Dazz
What model do you have?: T3 Syncro
Has thanked: 2 times
Been thanked: 4 times
Post by Dazz »
Good day All
As you may know I have bought two Bay Window buses from John Cloete.
The first one mentioning is Big Bertha We fetched Her on 24/05/2014. We drove to Nelspruit arrived at 13:00 Did the deal had a kuier and before we knew it, it was pointed out to me and John that it was 17:00.
My wife jumped in the Merc and me in the Bus and off we went. needless to say arrived home(Centurion) around 22:00. the Bus drove smooth the only thing that delayed us was the carb linkage popping off between the two carbs. We had a few extra chances at stretching our legs is how I see it.
So here is Big Bertha she has a 2000L Type IV.
This weekend 08/06/2014
We went to fecth AvO The bus is called this because its a lovely shade of Extra Medium Mint Avocado Groen.
This bus is complete and has quite an interesting story. John got the bus from an old Oom on a farm just outside Nelspruit. The Oom apparently bought the bus with 2000km on the clock and drove it for years until the heads pulled valves. He then parked the bus and took out the engine to have it repaired. When John saw the bus the Uncle said it had been standing like that for 8 years. John told me on Saturday that the Oom said the other day that it may be 15 years that the bus stood he can't quite remember, but it was for yonks and yonks.
My plan is to get AvO up and breathing again. The only bad bad rust I can see is on the front right hand gutter. Left front below the bumper. the floor right behind the driver and passenger seats and of course around the windows especially the middle windows. i would like to get a new motor, get her running and maybe seal the Paintwork. just repair the bad areas for now and give her a coat of clear.
The dash is uncut and the seats are mint.
How to properly check the OEL
The Interior
Sorry guys it seems I can only attach 10 pics.
Please feel free to comment.
Cheers
Daryl
Measure twice CUTonce.
1975 Kombie
1979 Kombie
W203 C320 CDI
'68 Austin Cambridge A60
Looking for a kombi project
hendriks
Been thanked: 13 times
Re: 1975 & '79 Bay Busses
Post by hendriks »
Hi Dazz.
Congrats man!!! Both busses look good. I prefer the look of the second one. Good luck with your project/s!
Keep posting pics. By the way. If you wanna post more than 10 pics, just reply on your own post the you can attach more pics.
Dazz
Post by Dazz »
Here are some more pictures
1975 Kombie
1979 Kombie
W203 C320 CDI
MrT
Has thanked: 22 times
Been thanked: 9 times
Post by MrT »
Well done! Will be following these busses with interest!
Dazz
Post by Dazz »
Hi all. So I am toying with the idea of just flatting the rust spots and treating them with rust convertor and maybe doing a clearcoat. Leaving the small original dents etc. I will just put new winfow rubbers in and respray the bumpers like new and refurb the wheels.
Or would you go for a full respray?
What are all your opinions.
1975 Kombie
1979 Kombie
W203 C320 CDI
You might be in for a shock when you remove the windows and rubbers but I hope this is'nt the case for you.
Are you using the bus ? Where is the worst rusted area ? Try keep the bus running while you tackle one thing at a time, don't strip everything in one go.
Perhaps once everything has been done then the time will be right for a full respray
Dazz
Post by Dazz »
The worst rust is on the sliding door window and the opposite window from the sliding door.
1975 Kombie
1979 Kombie
W203 C320 CDI
Have you removed the windows yet ?
Dazz
Post by Dazz »
No not yet. Only the bumpers.
1975 Kombie
1979 Kombie
W203 C320 CDI
Been thanked: 98 times
Portugal
Post by calooker »
If rust is showing in the window rubber edges, then the area under the rubber is completely rotten thru, guaranteed. A real bastard to repair.
Dazz
Post by Dazz »
@Calooker can a person buy those window section. im sure getting them to line up again will be a massive issue. what is your advise?
1975 Kombie
1979 Kombie
W203 C320 CDI
I'm sure you can get those repair sections, google "classicfab" to see if Gerson makes them. Jacques in PE might be able to order for you - keep us posted
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
Dazz wrote:Hi all. So I am toying with the idea of just flatting the rust spots and treating them with rust convertor and maybe doing a clearcoat. Leaving the small original dents etc. I will just put new winfow rubbers in and respray the bumpers like new and refurb the wheels.
Oh no, this is a bad idea, clear coat is no different to a normal base coat in terms of paint covering, if you simply want to flat the rust and spray over it, its just going to rust underneath and make it look worse than it is. There is no simple fix for rust.
My personal opinion on this bus, is that there is no patina on it, but rather a badly neglected rusty body. I would rather do it one time properly. Your major work is going to be fixing the rusty area's anyway, the rest is going to be easy.
Dazz
Post by Dazz »
Hi
So I swopped the wheels from AvO to Big Bertha. I like the look. the wheels have 205/70R14 tyres on and looks a lot more beefy.
I wanted to transfer the front seats also as Big Bertha had Hilux seats bolted in. I noticed that the original rails look different between the two busses. Were there different versions of seats as the years progressed the 75 seats doesn't fit onto the 79 rails. the lever mechanism for locking the seat hits the rail. the rail has a raised center section lika a halftube where the 75 rails don't.
When ive driven a distance and stop I can hear the oil dripping inside the engine. is this normal or would it be down to the viscosity being to little? I also notice a slight tappety noise at medium revs when the engine is warmed up. I doubt that its overheating as I can still touch most of the tins and the fan housing without it being extremely hot.
Any thoughts?
thanks
Daryl
1975 Kombie
1979 Kombie
W203 C320 CDI
Has thanked: 425 times
Been thanked: 543 times
I would not drive it till you done a full oil change, You do not know what :bn: the PO has put into the bus, also, after the oil change, do the tappets, as most guys are too lazy to do tappets so that may be your only problem.
Put in a good oil
