It's the Big 'n' Bulky sale...
Get your parts here
Merlin
Has thanked: 20 times
Been thanked: 39 times
Post by Merlin »
SPLIT BUS METAL
VERY crusty early '58 decklid...
The centre portion may be of use to one of you?
FREE. It's heading to the scrapper, soon...
Crusty Fleetline rear corners. Only one is shown, but I do have the other side, in the same condition...in Jo'burg. :roll:
Will need work.
R500 for the set.
Two high-hinge RHS cargo doors...
Will need work.
R2,000 each. Someone off of the forum does have dibs...I'm waiting for confirmation.
BUG
Late bug LHS door...
R500
2 x bug gearboxes...
One of them has a broken nosecone.
R1,600 for both. Slightly neg'.
PUMA
What's here:
  • Matched set of original Solex 40mm carbs
  • Original linkage
  • Original filters*
  • Original Puma intake manifolds
Notes:
  • * One of the filter tops has been modified to take a breather pipe.
  • The linkage rod seems to have been extended somewhat messily with a barrel nut.
R4,000
TYPE 4
1700 (block, crank, con-rods, 1800 flywheel (Type 4 engine > Type 1 gearbox))...
R1,500
Square port heat exchanges...
Negotiable.
Heater elbows...
R300
Dual carb' air filter...
Offers?
Shroud...
Offers?
217mm clutchplate...
R250
Heads...
R1,000
Additional 1800 flywheel, allowing for the fitment of Type 4 engines to Type 1 gearboxes. Hard-to-find! PENDING: Tony Z
R1,000
BAY'
Pedal Pan...
'68-'70 [ :?: ]
R400
I can bring all of these parts to Jo'burg, for a confirmed sale, sometime in the next two months, else feel free to organise your own transport from the Midlands/PMB area. :) The gearboxes may attract a nominal transport charge.
Unless otherwise stated, prices are non-neg'.
Nic
dixtoy
What model do you have?: 73 Beetle Patches
Has thanked: 60 times
Been thanked: 37 times
Re: It's the Big 'n' Bulky sale...
Post by dixtoy »
How much for the Fleetline hatch?
Merlin
Post by Merlin »
Sorry about that. Post edited. :)
dixtoy
Post by dixtoy »
PM send.
Retrobug
Has thanked: 15 times
Been thanked: 32 times
Post by Retrobug »
Nice pair of racks in the background! 8)
Merlin
Post by Merlin »
Eagle-eye. ;)
TvB103
What model do you have?: 1957
Post by TvB103 »
Hi
Just wanted to know if the decklid is still available?
Many tx
Merlin
Post by Merlin »
TvB103 wrote:Hi
Many tx
Coming to you soon...in the form of a fork...or a can...or :?:
Recycled.
Kaptein
Has thanked: 2 times
Post by Kaptein »
PM Sent
:puterwork:
Merlin
Post by Merlin »
Replied. :)
