Hi there air-cooled heads. I have a complete set of Single port heads with valves/springs/retainers/cotters up for sale. No cracks or hairlines. I have clean them up and took the no.3 exhaust valve out and reseat the valve that it can seal, clean the exhaust ports from carbon "will say 80% cleaning on that" . i replaced some of the exhaust studs with hi ten steel studs and nuts. original plug boss. One fin have a crack and one chamber have small marks of a screw. Photos attached to check. looks like 89 or 90mm barrel size, I just need to check with vernier on that. Sprayed the chambers and ports with oil that the valves don't rust.
Selling them for R700 for the set.
Drop me an Pm or call me on 0 seven 2 three 99 seven 2 seven 6
flatfourfan wrote:good sale............decent SP heads are getting hard to find and those look neat and best of all, no inserts......
Thanks flatfourfan. It is like you say there. I have a set of sleeves and 2 sets of T1 connection rods i need to post photos up to. 1 set is polish and balanced.
