- Wentzel
- Has thanked: 6 times
- Been thanked: 13 times
Hi Gerlach my engine is a 1776 with tdo4 Turbo, charge cooler and management. A diy system always under construction.
Oxyboxer Project
- Gerlach
- Oil Cooler
- What model do you have?: 1976 Type 1 beetle
- Has thanked: 9 times
- Been thanked: 4 times
Thanks for the info Wentzel. Sounds like a nice setup. Busy building an 1835 with a Rajay T-30 turbo with 2 36DRLA Carbs and MSD setup. What cam are you running on it?Wentzel wrote:Hi Gerlach my engine is a 1776 with tdo4 Turbo, charge cooler and management. A diy system always under construction.
- 62vwbeetle
- Oil Seal
- Been thanked: 12 times
Done by proxy by VdubTech crew , new fuel lines and pump, new coil , points plugs, condenser. Fuel tank cleaned new fuel filter. Carb body changed and new internals, fitted Gt 2 tip 4 into 1 exhaust. Tightened inlet set up.
I fixed window pillar,reconditioned and installed dash trim strip on cubby ,but most important i got to drive my Ghia hassle free , no idling no dying out or breaking down! YIPee thanks @bugger and VdubTech
- Has thanked: 18 times
- Been thanked: 58 times
62vwbeetle wrote:Done by proxy by VdubTech crew , new fuel lines and pump, new coil , points plugs, condenser. Fuel tank cleaned new fuel filter. Carb body changed and new internals, fitted Gt 2 tip 4 into 1 exhaust. Tightened inlet set up.
I fixed window pillar,reconditioned and installed dash trim strip on cubby ,but most important i got to drive my Ghia hassle free , no idling no dying out or breaking down! YIPee thanks @bugger and VdubTech![]()
Hey Brother dont worry I got stuck a few times test driving trying to diagnose the Problem but it was enjoyable break downs as you only got Thumbs ups from Passerbys
Enjoy and thanks for the Good words
- Gerlach
- Oil Cooler
Got back from the Karoo today. will upload some photos of the stuff that i have seen that i must get my hands on and take it back home.
- Gerlach
- Oil Cooler
After close to 5 months of crap strike of SAPO, my stainless valves from CB Performance have arrived. Thanks for the help Calooker, after all the crap you have to go through with that shipment. Will do business with you again.
Time to start my build thread.
- Wentzel
Glad you got it Gerlach good luck with the build and keep us up do date.
Oxyboxer Project
- Gerlach
- Oil Cooler
Thanks Wentzel. Will do so. Waiting for connection rods to land with my friend.Wentzel wrote:Glad you got it Gerlach good luck with the build and keep us up do date.
- 62vwbeetle
- Oil Seal
Refitted wiper motor blew a fuse , went for a drive, and laded up at VdubTech booked her in for a mini motor overhaul sorry guys. December seems to be my vw month suppose happens when have time on hands
- beetle786
- Camshaft
- What model do you have?: 1968 + 1303
- Gerlach
- Oil Cooler
Took my ride out for a coast ride just to get some fuel in her lungs. Was a super nice day this side.
- 62vwbeetle
- Oil Seal
Did a small trip in the splitty honeydew to home
- beetle786
- Camshaft
- Wentzel
Played with the timing map and took a drive. Feels ok but need more testing and fine tuning.
Oxyboxer Project
- beetle786
- Camshaft
. Old
new
