But I am installing a "new" battery inthe rat and then I can drive it
64 Notchback
- Has thanked: 78 times
- Been thanked: 37 times
Nothing yet
- Riekert
- Camshaft
- What model do you have?: 1964 Notch
- Has thanked: 111 times
- Been thanked: 23 times
Started with the notch again. Painted the floor in ns4 and stripped the rear fenders to do the samE
When they resprayed the notch they never took the fenders off... so needs a bit of treatment on the body and inside fenders. Will do the same on the front fenders this weekend: )
- Derek
- What model do you have?: 1971, 1972, 1978
- Facebook: Derek Antonio Serra
- Been thanked: 25 times
'72 Westfalia Weekender: We scrubbed the interior vinyl today - it's amazing how much grime had built up inside the camper in 40 years
Then I laid a new vinyl floor and tomorrow I'll fit a custom-built cupboard/fridge-freezer compartment behind the drivers seat...and swop the aftermarket rims for original rims.
'70 Dormobile - 1.6
'76 Brasilia - 1.6
'76 Brasilia - 1.6
- 62vwbeetle
- Oil Seal
- Has thanked: 6 times
- Been thanked: 12 times
Cool day took my single cab split for a drive to @bugger to visit my Ghia which seems to be progressing at a rapid rate.
Parts for Ghia all neatly laid out ready for install and bearings already in.
Left the bus to have some @vedubtech magic worked on linkages upfront making her easier to drive.
Will keep u posted when I drive them again
64 Notchback
Got the motor for the Spyder back from a friend that was putting it together for me.
Now I just need to spray the tin ware and assemble it.
- Riekert
- Camshaft
Awesome. So you kept both the spider and notch?64 Notchback wrote:Got the motor for the Spyder back from a friend that was putting it together for me.
64 Notchback
Yeah I still have both of them but the notch is still avail.
I could not get the price that I want for the Notch.
64 Notchback
Thanks for posting the pic Riekert
I decided to take the rat to work today. It made the 30km journey without incident only thing is when applying brakes it pulls to the right but that is not a biggie.
Now I just have to make the return journey.
hendriks
- What model do you have?: 71 bay
- Been thanked: 13 times
Took my 69 for a roadworthy.
failed.....
ball joint covers,
Tie rod ends,
Leaking brake hose at the back,
Rear indicator stopped working (now working again....)
The guy made some notes and gave me 14 days to go back. Part of the roadworthy trip was to find out what needs attention. So now I know....
failed.....
ball joint covers,
Tie rod ends,
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
Taking my 74 on Saturday. Expect it will pass first time.. Let's hold thumbs.
- Riekert
- Camshaft
How do you get it right to do it on a Saturday?acpaterson wrote:Taking my 74 on Saturday. Expect it will pass first time.. Let's hold thumbs.
- acpaterson
- Wentzel
Took the beetle to work today and had an erran or two in the hot weather. I was quite happy with the turbo's performance in this weather. The tune is improving but I'm still learning.
Oxyboxer Project
