When I just got the Bus, I wanted to inspect the brakes and general condition behind them wheels, but could, for the life of me, not get the &@#%^! wheel nuts to loosen....having turned/sheared one head CLEAN-OFF at the drivers side rear, I decided that some other measures are to be taken.
Having chatted to a fellow car-nutter at work (he just about only owns Porsches) he told me about the ATF & Acetone (50/50 mix) penetrating oil that works wonders, I Googled it, and voila, it is deemed as one of the best/cheapest Penetrating oil solutions around.... but it still did not get the nuts to loosen up. I've left the ATF/Acetone mix overnight, hit the nuts with the 4pound hammer, used a bit of heat...but NOTHING!!!
I've used just about any trick that I've known - Pipe on the spanner, Double-Spanner, 4Pounds on the spanner, heat on the nut and/or drum, penetrating oil, ... got my powerlifter buddy to give it a go....but NO SUCCESS!!!
Long story short, Friday night at the Jacaranda Beetle Club meeting, Hannes Schnetler confirmed that you need to make them wheel nuts RED-Hot, that should then separate any rust/oxidisation and/or any "Lock-Tite" that may have been put on them nuts (Where the "Lock-tite" made sense is that I've read in the Technical Advice that wheel nuts tend to come loose where rims have been freshly painted/powder coated, and not tightened properly - and then "Lock-Tite" get put on to counter the effect.
So Saturday I've bolted down to Builders and bought 1 of Plumbers Torch (working with the 190 gram Butane Gas cartridge) and gooiing about 1750'C:
Having that on the head of the "nut" for about 5mins (enough for the paint on the rim to start bubbling), and then HITTING it with the 4Pounds (enough to shock all unwanted dirt/grime/rust/gunk loose) gave the anticipated/required results. I chucked the wheel nuts into "Deoxidene"/Rust remover for a couple of minutes, gave it a good steelbrush work-over, then some Q20, and back it went.
So now I can take the bus for some tires knowing that the shop are not gonna shear off any nuts to an extend where the Bus might have to remain on the Lift at their shop! Quite a relief!
So the only challenge on the wheel nut removal is to get "The Sheared-One" out - I've seen the guys on the forums/YouTube welding a nut onto the sheared-off stud, and then using a ratchet spanner to turn it out - obviously the heat from the welding does the same as described above - so I shall hopefully get that out this week...
Now I can get the Drums skimmed, brake pads relined and fresh rubber on, and then hopefully hit the road.
