Or trade it all for a running bug
Or swop for something good I might be interested in .
Vw Beetle Gearboxes /engine Spares ,cylinder heads . engine tin , fan housings , alternator pedestal , alternators ,starters, petrol flaps . Fuel gauges ,1x 60,s model mechanical gauge with sender unit , fenders ,headlights ,tail lights /housings . Indicators . Rubber seal kit new . Heads lamp rings ,std / 4 into 1 exhaust system , front H beam , front and rear drum assemblies , new brake cylinders . Alternator parts , turn signal parts , speedo clocks , Door panel clips , bolts and nuts /clips /switches . Brake master cyl brake fluid bottle , brake cylinders old /brake star adjusters and springs / rubber brake pipes . Rear torsion bars with spring plate .carpet set with thick rubber padding ,front and rear bumpers . Fuel pumps , carburetors , distributors ,intake mani faults single and twin . Engine Gaskets , gearbox spigot shaft seal , gearbox mounts , rims with tires , 2x hub caps , some old rubber seals door handles inner /outer some have keys engine lid locks matching set , door panel tray etc ...
All parts are used unless stated they new .
Pls ask if you looking for anything specific then will see if I've got .
PM me if interested .
What's app or call 0784275792 for pics .
Thanks guys .
