1961 Karmann Ghia - Wiper Motor Removal
kthackwray
What model do you have?: Karmann Ghia
Post by kthackwray »
Hi there
Just hoping someone can tell me how to remove the wiper motor assembly from the Karmann Ghia
I found the bolts holding the motor assembly - just can't work out how to remove the "spline stalks" that the wipers attach to - On later models I think the nut slides over the "spline stalks" and then the whole lot just drops through the hole in the body but these don't so I am guessing I need to somehow remove the "spline stalks" - I tried "unscrewing" them with a bit of pressure but don't want to damage the splines - there also looks like a small pin / grub scres on the one side but I can't see a slot fro a screw driver or hole for allen key ?
Help - Please
John Alves
Has thanked: 3 times
Been thanked: 48 times
Re: 1961 Karmann Ghia - Wiper Motor Removal
Post by John Alves »
Is that not a grub screw I see on the side of the spline? I think you need to unscrew it, or is it a pin drilled in???
I think this is a modification done later to be able to fit later wiper arms
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
kthackwray
Thanks for the reply
You were right
Someone had modified them to take later wipers so I cut the pins off and got them off
Will have to see if I can fix or replace the wiper stalks when we assemble
Are the beetle motors directly interchangable ?
John Alves
are you asking about wiper motors or engines?
1968 1500 SP Beetle
