Front suspension
FreddeVilliers
What model do you have?: Beetle 1300
Front suspension
Post by FreddeVilliers »
Can anyone suggest why my 1971 Beetle 1300's front suspension leaks like it does? How does one fix it?
Re: Front suspension
There should only be grease inside your suspension beams, which might ooze rather than leak. What is leaking out of your suspension?
51splitfanatic
What model do you have?: 1957 Oval
Has thanked: 42 times
Been thanked: 13 times
Post by 51splitfanatic »
At least there is something to leak out of the front suspension...or ooze as Fig so eloquently mentioned......May need a clean up and then re-grease and see where it goes from there?
It sure as hell looks like 30years worth of grease on that portion of the beam. Not always people favorite place to clean a bus or beetle etc.
51Splitfanatic :hangloose:
FreddeVilliers
Thanks guys. I will clean up & regrease and see how she fares.
