Paarl. R3,500. Call Francois 0724096349
Weber 3236 carb and type1 manifold, R3.5k, Paarl
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Re: Weber 3236 carb and type1 manifold, R3.5k, Paarl
might fit a T4 with two manifolds when replacing a twin carb setup on a flat engine, but I doubt it will fit a 1600.
The design also screams "Flat spots"!!!!
- fig
- Bus Driver
Agreed. That manifold clearly won't fit the manifold ends of a type1 engine; maybe it will bolt on to twin carb manifolds.
A friend of mine had one of these on a type4 engined bus and on cool, damp mornings he had endless issues with manifold icing. He used to stuff a towel down one of the engine air vents to reduce air flow until the engine warmed up.
